rear suspension
Big Eb
rear suspension
Unread post by Big Eb »
Hi,got an Xantia 2.0 Hdi 2000 estate and i'm looking to source the T connector that sits above the cross member of the rear suspension, o/s/r,think it's a 6mm 6mm 4mm conecter. anyone have any idea where i could source this bit,Not having much luck at the moment with Citroen because when they ask for reg it's on Portuguese plates.
Cheers Eb.
x 6945
Re: rear suspension
We can sort that for you with your VIN, but as we are charged now, we ask for a contribution that will cover you up to 2 years for parts info:
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum.
Donate
Further Information
(Donor 2017)
x 39
Re: rear suspension
Unread post by 411514 »
Which part are you after. I assume its the suspension return piping you're referring to?
Does your car have Hydractive suspension? (count the rear spheres - if it has 3 rear spheres as in first diagram below it has hydractive)
If hydractive:
Part 10 is part number 5280 E2; Part 11 is part number 5280 87
If non-hydractive:
Part 8 is part number 5280 E2; Part 9 is 5280 87
In both cases, probably Citroen dealer only, can't imagine any pattern part manufacturer will have attempted a copy. Probably unavailable even from dealer though, so may need fabricate your own.
Sam
2003 C5 2.0HDI 110
Big Eb
Re: rear suspension
Ok ,cheers buddy,did make one but started to leak again,don't suppose you have a diagram for bottom hydraulic steering hose,the one that has pipe going into thick rubber hose then back to pipe,sits under the centre sphere.
Cheers Eb.
411514
(Donor 2017)
x 39
Re: rear suspension
Probably easiest if you look yourself if you know what you're after. There are loads of free online sites showing manufacturer diagrams. I usually use Catcar http://www.catcar.info/citroen/?lang=en ... Y3Qw%3D%3D, but there are plenty of others.
If you want part pricing information, you can use Servicebox - the part pricing info isn't behind a paywall.
Sam
2003 C5 2.0HDI 110
