I am looking to fit a towbar to my c4 grand picasso 2010 plate but can't find wiring diagrams with wire color codes for the rear light clusters so don't know what wires should be connected to the wires for the trailer plug.
Does any one have the diagrams for this please
2010 citroen c4 grand picasso towbar
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: 2010 citroen c4 grand picasso towbar
We'll need your VIN first.
V F 7*****************
Reason: VIN masked
Reason: VIN masked
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Focus on the Pin assignments, not the wire colours as these can change.
Rear Light Cluster on the body:
Note the Common Earth is on Pin 3:
Brake:
Pin 2 Live
Reversing:
Pin 1 Live
Rear Tail / Side Light:
Pin 5
Indicators:
Pin 4
Fog Lamps These I believe are in the bumper area and these are on Pin 1 and the Earth on Pin 2.
Brake:
Pin 2 Live
Reversing:
Pin 1 Live
Pin 5
Indicators:
Pin 4
What are the wire colors because I can't find reference to them anywhere.GiveMeABreak wrote: ↑04 Jul 2020, 21:42 Focus on the Pin assignments, not the wire colours as these can change.
Brake:
Pin 2 Live
Reversing:
Pin 1 Live
Pin 5
Indicators:
Pin 4
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
The pin numbers are marked on the black wiring plugs if you look carefully. As I said - the colours of the wires are often changed on PSA cars, so may not correspond. Always use the pin number as that is 100% accurate.
Look here for the numbers:
- My Cars: 2007 Citroen Grand C4 Picasso
sorry for reviving an old thread. does this apply to Citroen c4 grand Picasso year 2007 as well?
so, i can just follow this guide to install a towbar or a reverse camera right using the pin numbers?
im new btw, do i need to intro myself anywhere.
- My Cars: C4 grand Picasso 2008
407 Peugeot 2006
307 Peugeot
Mercedes sprinter van
914 Porsche
VW caddy
Thank very very much. I had been look and look at wiring diagrams. and in some cases there were multiple wires going through a connection pin the same colour. Your pin number System has solve the problem.
Just as an extra,
I want to put in daylight running lights and an indicator repeater at the front. Therefore one would just look for the plug pin numbers assuming pin number 4 again would be the indicator at the front of the car.
Best Wishes
Clemesha
Just as an extra,
Best Wishes
Clemesha
