Hi all, looking for some help recently purchased a C5 needed new calipers and when the garage was installing ( national tyres) they snapped the handbrake cable so need to get a new unit
Can anyone confirm of it's possible just to get the cable changed? Or is it a complete unit? Or anywhere to be repaired?
I found one through a breaker for 200 but don't know how I can check if it would fit my car ( is this something Citroen could do through the vin numbers ?
Thanks in advance for help
C5 HDI Exclusive Electronic Handbrake
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5723
Re: C5 HDI Exclusive Electronic Handbrake
The cables are not available separately and a new unit is about £1015.00 inc. VAT ex. fitting.
Bad move taking it to these people - obviously not familiar with the system, The electronic handbrake system needs to be put into removal mode prior to replacing the calipers and that is a likely reason why they snapped the cables I suspect.
In any case, they mucked it up - they should have insurance against this sort of thing - so get them to have it done properly at a dealership and pickup the bill. I would not get involved with doing anything yourself at this point or they could use that to deny culpability.
- My Cars: Citroen C5 Exclusive HDI 2009
Thanks, that's my problem though as I driver the car out of the garage already. They said they did but have no way of proving it
I found a second hand unit for 200 but don't know if it would fit ( and don't want to buy without confirming ) just wondered if anyone else had experience with this before
Would really appreciate if anyone could help point me in the direction of somewhere I could have Von numbers cross referenced on the handbrake units to see if an aftermarket unit would fit
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
I cant help Steven, but agree a second hand unit is the way to go.. 1015 plus fitting is probably more than my x7 is worth
someone will help with part numbers
John
John
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
We can supply you with the correct PSA part number for your vehicle, please see below:
A response to your question by a forum admin will require detailed vehicle information that requires you to have made a current contribution to the Forum. |
Donate Further Information |
