Hi All,
When clearing some faults the above appeared as a permanent fault
P2425
Control of the bypass of the EGR exchanger
Open circuit.
Could this be the control solenoid valve ?
Kenny
fault code P2425
KennyW
- x 165
fault code P2425
C3 1.4 petrol (SWMBO)
- x 6956
Re: fault code P2425
P2425 on this engine ECU is the control of the EGR Exchanger Bypass being 'open circuit' for 2 seconds Kenny.
It may disappear after 5 minutes but only when the engine is hot. The fault will cause the deactivation of the initialisation of the EGR valve.
Possible causes: Electrical harness, Connectors, EGR exchanger bypass control solenoid valve, EGR exchanger bypass, Fuse.
KennyW
- x 165
Thanks Marc,
I shall check everything over.
Kenny
Kenny
KennyW
- x 165
Here is a diagram done for the Vacuum system involving the 3 control solenoids relating to C5 X7 post 12291
Kenny
Kenny
KennyW
- x 165
Well changed the solenoid and cleared fault.
I've noticed the car is a little bit more responsive since the change and the fault has not returned.
Hooray one thing less thing to fix but back to the the wiring to and from the suspension ecu ( another thread).
Kenny
Kenny
