Would anyone happen to know if the 206cc headlights are the same as other 206's or are they peculiar to that model?
Cheers
206cc headlights
moizeau
- x 423
206cc headlights
Pete
- x 6945
Re: 206cc headlights
On both the first and second generation 206s, there are 2 versions of headlamps - one with single and one with double optic lamps Pete. This applies to each generation of 206.
moizeau
- x 423
Cheers Marc, the reg is CU04FPK
It seems that they are the same across the range irrespective of model. I saw on Pieces auto they are about 30 squids new!!!
Pete
- x 6945
Can't help with the reg now Pete - GDPR requirements - so will need the VIN.
No, they are not the same Pete - they mak LOOK the same but they aren't.
| MK 1 CC Single Optics | MK I Single Optic | MK II Single Optics (but there are 2 versions of lamp depending on build date. |
moizeau
- x 423
Cheers Marc, I'll get the Vin tomorrow. Thanks
Pete
OnlinePaul-R
- x 1939
Pete, if you're going to look at the car to get the VIN why not get the RP number instead?
See here for information https://frenchcarforum.co.uk/wiki/ORGA/RP_Number
- x 6945
The VIN is better as it will actually tell me what version of lamps it has and I can get the RPO from that too if needed.
moizeau
- x 423
Pete
- x 6945
Ok, so that's a December 2003 Build Cabriolet, with Double Optic Headlamp Unit:
Part Nos:
6204T0 (left)
6205T0 (right)
Part Nos:
6204T0 (left)
6205T0 (right)
moizeau
- x 423
Thanks Marc, it's for a mate (the chap that bought my van over in the back of his lorry). I'll cross reference the numbers to see if it's a standard headlight across the range, bearing in mind that 3 versions exist and find the equivalent LHD part numbers for the same headlight.
Thanks again
Thanks again
Pete
moizeau
- x 423
I think it's this as it states H7/H7 and the others state H4
https://www.piecesauto24.com/van-wezel/1291065
Not a bad price new.
Pete
techjam
is there any site to cross reference 1 part number with other models to see which parts are compatible on which models?
moizeau
- x 423
Check your bulb type physically then use the part numbers on Misterauto or similar and confirm the fitment.
Pete
