Identifying VIN
- Injection
- My Cars: '06 Citroen Berlingo Multispace Forte
Identifying VIN
Hi there!
I'm in a situation where I have no original VIN of the car but hopefully the engine's and transmission's serials match and could lead to identifying the original VIN of the car. I know that this might be a lot to ask, but hey, you never know before a few old FCF members tell you it's not possible that way.
Anyways here are my markings from the engine and the gearbox. Oh, of course I have my tire pressure label too.
Engine:
"KFW" "10FST5"
"PSA" "5436607"
Transmission
"20CP37"
"2026444"
Tire label:
10740 - 2006.04.04
FV - Vigo, Spain
1st assembly line
0996
KDDC - Sable Bivouac
Engine:
"KFW" "10FST5"
"PSA" "5436607"
Transmission
"20CP37"
"2026444"
Tire label:
10740 - 2006.04.04
FV - Vigo, Spain
1st assembly line
0996
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
Re: Identifying VIN
It's not generally a good idea to knock the members on a first post!
As for the VIN - no. You may only be able to work out the first part of the VIN, but not the second (VIS) as that is part of a serial number that is designated at the factory and won't relate to the engine or gearbox.
If you have not found it on the bodywork anywhere or on the lower outside windscreen cut out, then you are out of luck I think. That's why it is stamped in several locations.
For a MK I or II Berlingo the VIN is also stamped on the front wing inner panel as shown:
- white exec
Re: Identifying VIN
Insurance, taxation or inspection/testing documents might also carry the VIN.
As Marc says, it's usually marked a car in several places, as a stamped-on or engraved number.
MoT testers here always check it corresponds to the paperwork.
If you have a factory-made car where all the VIN markings have been removed, I guess the police might be interested!
- Injection
Re: Identifying VIN
Yeah, I kind of have guessed the first VIN part myself too but VIS is where the trouble starts.
I'm thinking, it might be something like "VF7**************[VIN obfuscated, can be read by forum staff]***VIS**"/ES, correct?
Actually I have all VIN's but the one under the windscreen, but they don't match the tire sticker, nor engine. Car has had an collision in it's past where insurance has paid out its value. I too suspect that it has had a body swap but though the engine is carried in its paperwork, VIN is in its BSI and so on. I don't know, is there any lead I could be looking for anymore.
I guess that just a car owner asking the dealer or factory about its car would be pretty much ignored with that sort of application. Or what do you guys think?
- white exec
Re: Identifying VIN
VIN sometimes also engraved on the floor pan/cross-member, visible when a front seat is slid back, sometimes under a lift-off plastic cover. Done to double up on ID, and to avoid loss when a major front end repair is done. May not apply to PSA though.
- Donor 2023
- My Cars: C5 Mk2 VTX+ estate.
- x 3008
Re: Identifying VIN
On my C5 that VIN plate is under the back seats.
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
Ex C5 2.0HDi VTR
Ex C5 2.0HDi VTR
C5 2.2HDi VTX+
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
Re: Identifying VIN
Under the screen, on the right wing/chassis leg and as below. If it is not on the bulkhead as well then there is something VERY smelly about the car.
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: Identifying VIN
The last 8 alphanumeric is the VIS and that will not be on tyre labels or anything else. Only the factory allocate this code.Injection wrote: ↑01 Apr 2020, 04:56 Yeah, I kind of have guessed the first VIN part myself too but VIS is where the trouble starts.
This is how a typical VIN is made up - and in this example I have used a fictitious C5 X7.
VIN Code as we refer to is: V F 7 R D R H R 8 9 L 0 0 0 0 0 0
VIN Part = V F 7 R D R H R 8
In this example:
Manufacturer Part
V - 'Car'
F - Country France in this case
7 - Manufacturer - 'Citroen' in this example
Vehicle Family
R - Citroen C5
Shape
D - 5 Door Saloon or W- 5 Door Estate / Tourer
Engine
RHR - Engine Code, in this case DW10BTED4 100 kW
Gearbox
8 - 6 Speed Manual Gearbox in this example
VIS - this is the next part of 8 characters & consists of 4 alphanumeric and 4 numeric 9L000000
9 - 2009 Year
L - Factory Code:- Rennes in this case
Code
The next 6 digits will relate to the car identifier itself.
I doubt they will hand over a VIN for obvious reasons - I suspect the VIN would always be the same for the vehicle as a whole and would not be changed even if the engine was swapped of course, - but you'd be expected to get some sort of invoice / documentation with the replacement engine to confirm its identification that you would normally keep in case you got stopped
- My Cars: MK2 '17 C4GP 1.6 BlueHDi 120
'13 3008 1.6 HDi GripControl - x 1003
Re: Identifying VIN
If you can get access to a Diagbox system, and plug it in, it should read the VIN that is in the BSI.
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
- Injection
Re: Identifying VIN
Thanks for your input guys! It looks like I have actually seen/tried/looked for everything I have come up or anyone have suggested so far. Seems like basically only sources could be the guys who did the swap and factory that built it in the first place.
- Donor 2023
- Lexia Available: Yes
- My Cars: C5 X7 2009 2.0 HDI VF7**************[VIN obfuscated, can be read by forum staff]
C4 2010 2.0 HDi Exclusive VF7**************[VIN obfuscated, can be read by forum staff] - x 378
Re: Identifying VIN
What part of Estonia are you in, we have a few members that have access to the equipment that can get you the vin ?
- Donor 2023
Re: Identifying VIN
It appears not looking back at posts, something basic that can be done with a Lexia hence my previous post as we have members from all over the world that have them and are more than happy to help
- Donor 2023
Re: Identifying VIN
Done a quick google search, 3 Estonian Citroen dealerships flag up, a quick diagnostic session will give the vin number and vehicle history if no forum members are available.
Not checked for indies but guess there will plenty
