Radio Aerial Antenna C5
xf1ref
x 11
Unread post by xf1ref »
Hello Everyone,
I have a strange noise from the back side of the roof panel in the area where is the aerial antenna. On Citroen service I saw that the aerial base is fixed with a nut from the roof.
I'm wondering if there is a way to remove the aerial antenna base without removing the whole roof panel? If not, does anyone know if the roof panel is glued or how can be removed?
x 5587
Re: Radio Aerial Antenna C5
On earlier C5s at least, the aerial is accessed through the rear interior light assembly.
Have a look and see if your's line up.
xf1ref
x 11
I have removed the rear light but there is some kind of frame made of foam. Is called ROOF WEDGE on diagram from service citroen.
x 6956
Unfortunately it's a bit more involved on the X7, so I would definitely check the units in the first part of the procedure below, in case they are faulty.
Radio Aerial Units Only:
Disconnect the connectors ( as "a", "b").
Remove:
  • The bolts (2), (3)
  • The audio equipment aerial units (1), (4)
Radio Aerial
Remove:
  • The rear shelf
  • The quarter panel lower trims
  • The rear screen pillar trims
  • The quarter panel trims (Rear )
Partly release:
The headlining
Disconnect the connectors (At "c" and "d").
Release the harness (5) (Radio aerial) ( as "e").
CAUTION: Always replace the headlining if
there is any damage or marking.
Release the harness (5) (Radio aerial ( as "g").
Move aside the headlining (6).
Release the harness (5) (Radio aerial) ( as "f").
Unclip: The fixing ( as "j") using trim tools.
Release the harness (5) (Radio aerial) ( as "h").
N.B.: Gain access between the headlining (6)
and the roof crossmember (7) (In the direction of the arrow ).
Unclip: The mountings ( as "k") using trim tools.
Release the harness (5) (Radio aerial).
N.B.: Gain access via the rear courtesy light lamp.
Cut: The soundproofing (8) ( as "l").
Remove the nut (9).
Detach and remove: The audio equipment aerial (10)
and the audio equipment aerial harness (5),
Notes:
CAUTIONS:
  • Guarantee the sealing between the base and the roof to prevent the entry of water.
    As the roof light is located near the base, poor sealing could result in short circuits.
  • Take care to reposition the harness correctly when refitting the nut (9).
Apply a continuous bead of mastic, approximately 0.5 mm thick, to the audio equipment aerial base (10) (Index: "A1").
Proceed in the reverse order to removal.
Tighten:
  • The bolts (2), (3) to 0,8 da.Nm
  • The nut (9) to 0,8 m.daN
2 minute job as you can see :-D
x 5587
That looks a right faff.
xf1ref
x 11
Just wow, I'm thinking maybe I can live with that noise :-D
Looks like I can get to that nut through the rear lamp but I have to cut that soundproofing foam.
Thanks a lot for the procedure , It's really helping me.
x 6956
No worries - at least you know what is involved - checking the units under the rear parcel shelf should be relatively easy to check condition.
