Citroen Picasso Desire door won't open from outside
DaveHull
Unread post by DaveHull »
Hi everyone,
I own a Citroen Picasso 1.6 Desire 2008 plate. Recently I had a scrape with a bollard, and now the rear left hand side door won't open from the outside. It still opens from the inside, but when you try the outside handle nothing happens. You don't hear anything moving in the door.
Any ideas how I can rectify this as I have an Mot due soon?
Many Thanks
Dave
moizeau
x 429
Re: Citroen Picasso Desire door won't open from outside
Unread post by moizeau »
You'll need to take the door card off, then you'll see more clearly what's not happening.
Pete
x 6955
As Pete says, you really need to have a look at this as the MOT states "Driver and passenger doors must open from the outside using the relevant control".
Does the vehicle lock ok? If so, the electronic module will likely be alright. We really also need a VIN to determine the exact system you have as there are differences in the locking mechanisms depending on build date. But generally speaking, some models have a cable link from the internal door release handle to the door lock module. As this is operating when you open the door from the inside, it is likely that it is the external door handle mechanism that has possibly become detached and / or damaged.
Once we have your VIN, I can put up a diagram to show the components.
x 1484
There's only one design on Xsara Picassos, and it's rod operated. Likely that the impact has dislodged the rod or broken the handle. Door card off and it will become apparent; should be able to get parts from a scrapper.
x 6955
For some reason I was looking at the C4 Picasso - which has at least 2 different types.
So it will likely be item (2) - the outer door control rod that may have become detached.
x 1484
That's the front, Marc, but the rear is similar....
x 6955
As you can see, I'm totally on the ball today!
Thanks Richard, I've corrected the image above to show the rear door. Off to batten down the hatches now ready for the storm. :snowman:
DaveHull
Thanks for all the replys, fingers crossed it will be an easy fix when I get the door card off.
Cheers
Dave
