Front Sphere
froggy
- (Donor 2026)
- x 4
Front Sphere
Hi, need to order the front sphere, for my S1 Xantia, which sits by the rad. whats its official name ? cheers Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
- x 3295
Re: Front Sphere
That is the accumulator sphere.
Removing it can be tricky if it is tight. Drop the suspension to its lowest setting, and turn the engine off. There is, on the accumulator mechanism, a bolt with a raised head. Turn this bolt through 360 degrees (do NOT undo it completely, as there is a small sealing ball bearing under it, and removing the bolt will allow it to make a bid for freedom!). Once the whistling has stopped the hydraulics are no longer under pressure. You can now (carefully) remove the sphere, but it may well be tight (so you may need force, which is tricky considering how close it is to the radiator).
- x 1751
Re: Front Sphere
Just to be sure, either post a photo of the sphere in question, or post your VIN.
IIRC, both Accumulator sphere and Hydractive centre sphere are up front near radiator.
- x 3295
Re: Front Sphere
Ah, I didn't think of that!
However, as Froggys' signature suggests a Series 1 LX Xantia I might still be right.
- x 1751
- x 1438
Re: Front Sphere
In the Xantia range only VSX, Athena, Activa and Exclusive spec had hydractive. About 90% of Xantias didn't have it.
- x 6954
Re: Front Sphere
Froggy has an XUD9TE (1.9 TD) S1, so no Hydractive Suspension, so he's referring to the front Accumulator Sphere.
So Citroen part: 95666763 (400CM3 62 BARS) includes gasket,
or their cheaper equivalent part: E587001, includes seal.
froggy
- (Donor 2026)
- x 4
Re: Front Sphere
Its leaking from the seal. what is the best option, take off and clean seal and replace or new seal or finally new sphere ?
Terry
- x 6954
Re: Front Sphere
The seals should always be replaced when the spheres come off, but I'd certainly get some new seals first of all.
The seal item number (6) in the above diagram is part number: 527215 (37.4 X 42 X 2.6). In the UK they are £5.88 each from Citroen inc. our 20% VAT, to give you an idea.
froggy
- (Donor 2026)
- x 4
Re: Front Sphere
cheers
Terry
- x 3295
Re: Front Sphere
Normally (but NOT always) a replacement sphere will come with a replacement seal. The exception to this is the anti sink sphere (which uses a tube seal). Just make sure that the seal is properly seated before tightening up the sphere, otherwise you can pinch and split it (you can guess how I know this).
- x 1438
Re: Front Sphere
And (just in case no-one told you), the seal is fitted into the recess in the regulator body before fitting the sphere, not fitted to the sphere neck and screwed on.
