winchman wrote: 30 Jan 2020, 16:22Different situation but this is how to check for leaks , its a different situation bear in mind , but this leak finding is sort of the same.Huskyxantia wrote: 30 Jan 2020, 16:17YouTube has lots of videos on how to do this its the same principal for all cars have a Goole how to find vacuum leaks with wd40 your find lots
Also have you tried toe starting the car ?
If that works then rule out the starter motor if it don't start then I'd go the leak vacuum route
I didn't know it had any vacuum stuff on the engine?
Another thought to consider
2.0HDI Picasso poor starting
Huskyxantia
- x 869
Re: 2.0HDI Picasso poor starting
Husky.
winchman
- x 11
EGR has been in fault for years never made a difference to the driving or starting
Huskyxantia
- x 869
That rules that out then idcof thought it would throw a light upwinchman wrote: 30 Jan 2020, 18:39 EGR has been in fault for years never made a difference to the driving or starting
Husky.
winchman
- x 11
It does occasionally but easily reset going to go out in a moment and see how it is this morning, not that cold thoughHuskyxantia wrote: 31 Jan 2020, 07:15That rules that out then idcof thought it would throw a light upwinchman wrote: 30 Jan 2020, 18:39 EGR has been in fault for years never made a difference to the driving or starting
Huskyxantia
- x 869
Pity you couldn't borrow a spare starter from somewhere/someone.
And if it is low fuel rail presser that may well cause issues to a new starter after a while , any black gunk around the injector seal area ?
Husky.
winchman
- x 11
Tried my local scrap man he didn't have one I can repair the starter its just difficult for me to remove. Do you mean gunk around the injector?
Huskyxantia
- x 869
I viewd a Picasso a few weeks back it had poor starting and smoked and the engine rattled and the person selling it said pump the throttle ... Several times ... Which a diesel don't need it , petrol yes.winchman wrote: 31 Jan 2020, 07:28 Tried my local scrap man he didn't have one I can repair the starter its just difficult for me to remove. Do you mean gunk around the injector?
I noticed black crude dark oil around number 1 and 3 injectors, plus the air box was missing and well it was a heap.
Poor starting is lots of things
Glow plugs
Any fuel connected items with joints and wear and suck in to much air
Water in the fuel, my last xantia used to leak around the fuel cap and hard rain it would get in and a few days running it would run lumpy or take time to start,
My zx had starting issues I purchased a new starter motor off eBay ... It didn't work i put the original one back on and 5 months its starting brilliant ,
Possible battery terminals could be lose or need cleaning too , under one of the seats one the Picasso as you no.
Spray wd40 around and air duct around the turbo where the pipes connect if engine revs high when spraying then that means a leak.
Also ... Oil blockage in the intercooler can make for poor starting too.
Could you film the car being started up ?
Make a little video then folks can see
Husky.
Michel
Just replace the starter motor with the one I linked to. If it doesn't solve the problem I'll pay for it myself!
winchman
- x 11
Thanks!Michel wrote: 31 Jan 2020, 09:52 Just replace the starter motor with the one I linked to. If it doesn't solve the problem I'll pay for it myself!
I am hoping to remove it and have a look next week
winchman
- x 11
Little Village near liverpool
winchman
- x 11
On another note I got my self a spare fuel filter housing from the scrappy and stripped the lid off my old one lubed it and tightened it to be certain its not leaking.
- x 1751
winchman
- x 11
No far too posh for me
Kennyd90
- x 5
It's a starter motor. All PSA diesels with starting problems is due to a worn starter motor!!!
