Petrol fumes from THP engine
x 1455
Unread post by xantia_v6 »
Our 308 CC with the EP6-CDT engine has started to smell of petrol, but it seems to be intermittent. The fumes are raw fuel (not exhaust nor crankcase fumes) and seem to be drawn in through the air conditioning system, usually after idling at traffic lights or similar. Annoyingly it has never happened at home, not has any smell been detected under the bonnet.
I have looked at all the visible fuel lines under the bonnet, and the vapour purge valve, but there is no sign of any leakage. The engine is running perfectly.
The crankcase fumes smell awful, but not of petrol.
I have also checked the connections to the high pressure fuel pump, but there is no leakage at either pipe. It is almost impossible to see the injector fuel rail, maybe it can be seen from underneath with the exhaust pie disconnected, but I have not gone that far yet.
Has anyone heard of any places where these engines leak?
x 1240
Re: Petrol fumes from THP engine
Unread post by Peter.N. »
Haven't had a petrol engine for many years so not familiar with modern ones, the only thing I can suggest is that you stop as soon as possible when you get the smell, lift the bonnet and have a good sniff/look.
x 5673
My mate had a Carina II that was perfectly fine until the sunroof was opened, after which the cabin filled with an overwhelming petrol pong.
Never did find out why.
x 1751
The annoying thing about petrol weeps is that they remain pretty much invisible :(
Not much help...
x 6957
Here are the known areas of petrol leaks. If you can narrow it down to one of the zones I can get a bit more detail. If the smell is coming in more or less as soon as or shortly after the engine is started, then more likely to be a fuel leak and - obviously near the air intake.
ZoneDescription
Zone "A"Filling pipework assembly
Zone "B"Fuel gauge and pump assembly
Zone "C"Fuel tank
Zone "D"Pipework to engine
Zone "E"Canister absorber
Zone "F"Fuel filter
x 1455
Funny that the official list does not include the high pressure fuel pump or fuel rail, which are the 2 (expensive) components that come up as culprits for the same engine in a Mini.
I will look again at the HPFP. I hope that it is not the fuel rail, this picture shows the fuel rail from above after the manifold has been removed for access.
x 6957
Sorry - I had to go and have just got back after a long afternoon - there is another one for the Engine Circuit - let me know the zone of interest:
[b]Zone[/b]
Description
Zone "A"Timing face
Zone "B"Coupling face
Zone "C"Inlet face
x 1455
I have spent some more time on this, and have found that the petrol fumes seem to be coming from the rear or timing end of the engine (zones A and C), but the fumes are only present when the engine is running, not when switched off nor with just to low pressure part of the system pressurised. This is not good news, as the high pressure components are almost inaccessible, and generally expensive.
Marc, can you find me the troubleshooting guides for engine zones A and C?
x 6957
Will do, leave it with me...
x 6957
Finally... :)
There are 2 sections - Leaks by Area (Zones A, B & C) or by known cases in the following table.
Leak Diagnostic by Known Cases
ProbabilityLocating the leakZone
LowFuel supply pipe on high pressure fuel pumpCoupling face - Stage B2
LowHigh pressure fuel supply pipeInlet face - Stage C1
LowPressure sensor on the fuel high-pressure injection railInlet face - Stage C2
LowFuel injectors on the fuel high pressure common injection railInlet face - Stage C3
LowPlug on fuel high pressure common injection railInlet face - Stage C4
Leak Diagnostic by Area
Zone A - Timing Face
A1: Fuel Connection Towards Adaptor
Locating the LeakInformation
Sealing: Hoses force-crimped on click-fit unions
Probability: Low
Possible causes:
  • Incorrect crimping of the hoses
  • Damage to the click-fit unions
Access: Easy
Repair: Replace the fuel pipes
Zone B - Coupling Face
Stage B1: Canister pipe on air inlet
Sealing:
  • 2 O-ring seals
  • Pipe force-crimped on click-fit union
Probability: Low
Possible causes:
  • Incorrect positioning of the fastener
  • Seals sealing fault
  • Absence of seal
  • Incorrect crimping of the pipe
Access: Average
Repair: Replace the canister pipe on the induction
Stage B2: Fuel supply pipe on high pressure fuel pump
Sealing:
  • 2 O-ring seals
  • Hose force-crimped on click-fit union
Probability: Low
Possible causes:
  • Absence of seal
Access: Average
Repair: Replace the damaged low pressure fuel piping
Stage B3: High pressure fuel pipe on fuel pump
Sealing: High pressure pipe distorted against the cone on the pump
Probability: Low
Possible causes: Incorrect tightening of the nut
Access: Average
Repair: Replace the high pressure pipe
Zone C - Inlet Face
Inlet face - Injection system.
Stage C1: High pressure fuel supply pipe
Sealing: High pressure pipe distorted against the cone on the rail
Probability: Low
Access: Average
Stage C2: Pressure sensor on the fuel high-pressure injection rail
Sealing: Cone shape of the sensor tight against the rail
Probability: Low
Possible causes:
  • Sensor incorrectly tightened
  • Fault with the contact surfaces
Access: Difficult
Repair: Replace the pressure sensor on the rail
Stage C3: Fuel injectors on the fuel high pressure common injection rail
Sealing:
  • Detachable O-ring seal
Probability: Low
Possible causes:
  • Gasket sealing fault
  • Absence of seal
Access: Difficult
Repair:
  • Replace the 3 seals and the injector clip
  • Check the tightening torque of the plug on the fuel high pressure common injection rail
Stage C4: Plug on fuel high pressure common injection rail
Sealing: Force-fitted plug
Probability: Low
Possible causes: Incorrect positioning of the plug
Access: Difficult
Repair:
  • Replace the plug on the fuel high pressure common injection rail
Inlet face: Fuel vapour recirculation circuit
Stage C5: Fuel vapour recirculation pipe on canister purge electrovalve
Sealing:
  • 2 O-ring seals
  • 1 Clip
Probability: Low
Possible causes:
  • Absence of seal
Access: Difficult
Repair: Replace the fuel vapours recirculation pipe
Stage C6: Fuel vapour resuction pipes on canister purge electrovalve
Sealing: Pipes force-fitted
Probability: Low
Possible causes: Incorrect fitting of the pipe
Access: Average
Repair: Replace the canister pipes
Stage C7: Fuel vapour hose on air inlet manifold
Sealing:
  • 2 O-rings in the click on union
Probability: Low
Possible causes:
  • Fault with the seals
  • Absence of seal
  • Incorrect fitting of the pipe
Access: Average
Repair: Replace the electrovalve
x 1455
Thanks Marc, that gives me a few ideas for things to check. I am still trying to establish a pattern of when the petrol smell occurs. It seems that it is not present when the engine is cold, nor to any great extent when the car is stationary. This makes tracing a bit difficult as the engine must be cold and partially dimantled to get to a number of the relevant components.
x 6957
No problem, I do hope it is in an accessible area Mike.
x 1455
No luck yet isolating the source of the fumes. I did go as far as removing the inlet manifold to check the fuel rail and other hoses down there, but no sign of a leak.
I am now suspecting that the leak might actually be the A/C evaporator. The A/C is still functioning well. but we seem to only smell the fumes when the refridgeration is turned on (and the evaporator cold).
Out of curiosity, I tried to find the part number of the evaporator, but it seems that it is not listed as a separate part (you have to buy the complete heater housing), and it is not clear whether they are are available after-market (as there is no part number to search on).
I will visit a local A/C specialist who should have a gas leak detector.
x 1751
UV tracer dye for AC, Mike - something that could be left in, and which you could detect yourself, if the sniffer doesn't find anything.
x 1455
Yes, but dye is not much help for a leak in the evaporator... I have checked all the A/C plumbing under the bonnet and nothing is oily. Having looked some more, it seems that sourcing an evaporator at a reasonable price for a 308 is a real issue, as none of the usual vendors list them.
