cd changer
This section is for General Enquiries or for Systems not Covered Above
maxxo
x 15
cd changer
Unread post by maxxo »
Hi all,
Yet another late night thought........
So i would like to install a cd changer (have this weird thing about it being period correct) to my 2005 citroen xsara picasso.
Now i'm aware the wiring loom is unlikely to be in place for this, however i have literally no idea where to start on this.
i'm thinking if i get a standard wiring loom........at least that's what i imagine and the clarion unit from a scrapped picasso this should in theory work, however i have quickly searched online and i have been unable to find a wiring loom that looks to be compatible.
if anyone could be of any help that would be much appreciated.
x 1454
Re: cd changer
Unread post by xantia_v6 »
Before we can give you any advice, we need to know which audio system is currently installed. If you post your VIN, somebody can look it up for you.
x 2941
Re: cd changer
I don't know about the Xsara but my C5 has the loom and connectors already in place under the driver's seat.
Michel
Re: cd changer
Unread post by Michel »
The 03 Xsara Picasso that's been dumped on me seems to have them under the driver's seat too.
Michel
Re: cd changer
Michel wrote: 20 Dec 2019, 09:54 The 03 Xsara Picasso that's been dumped on me seems to have them under the driver's seat too. It is a "Desire" model though.
I'm unsure what's desirable about it though.
x 6957
Re: cd changer
The CD changers were not fitted as standard equipment on the Xsara Picasso’s - even on the Exclusives, but were available as an accessory, so they all should have the wiring loom there as standard.
They operate on the comfort VAN network, so make sure you get the correct one.
maxxo
x 15
Re: cd changer
sorry to bump my old thread
so after doing research it seems it should be prewired for it under the drivers seat, now i have taken a quick look tonight and couldn't see anything apart from the airbag connectors
would it be under something or hidden away?
x 2941
Re: cd changer
This is the connector on my C5.
