Diagbox turbo pressure measure
Slobo2712
Unread post by Slobo2712 »
I have diagbox 7.81 and peugeot 307 1.6hdi 80kw.Im interested how to test turbo pressure,and how to see does turbo has normal or lower pressure?Tnx in advance
x 6963
Re: Diagbox turbo pressure measure
You'll need to run a global test first, then go onto the engine ECU. Once selected and confirmed, you will have a menu from which you can select Standard Parameters or pick your own. Select the most appropriate for what you want.
Slobo2712
GiveMeABreak wrote: 27 Nov 2019, 01:12 You'll need to run a global test first, then go onto the engine ECU. Once selected and confirmed, you will have a menu from which you can select Standard Parameters or pick your own. Select the most appropriate for what you want.
Tnx but I know where to find it.I mean which parameters are correct,for example how much mbars or psi needs to be for 2000rpm,3000rpm and so on..?
x 6963
There are no tables listed for what the values should be at certain revs, but there are reference values that you can compare with when using standard parameter tests:
In the Air Intake Circuit for example, I have highlighted the readings - see if the reference value changes as the engine increases...
Slobo2712
Ok tnx,so correct turbo pressure should be same as reference value?At me reference value is always bigger than pressure?
x 6963
If you are concerned about the turbo pressure - you'll really need to check the turbo pressure sensor and turbo position copy sensor readings from the parameters in Diagbox compared with a physical gauge attached to the circuit.
I can only tell you what the sensor voltages correspond to in mbars.
Slobo2712
800 rpm
3200 rpm
I have changed new electro vacuum valve
x 6963
Nice one. Sometimes the filters on these get blocked up and the vacuum is very poor.
Slobo2712
Tnx for answer so as i understand on second image 3200rpm turbo pressure measured needs to be also 1600?
Slobo2712
Can somebody tell me how to see is everything ok with MAF sensor with diagbox?Tnx
x 1432
Unread post by xantia_v6 »
Were the screen-shots above taken with the engine under load, or just free-revving? I would expect an error code for low boost to be thrown if the conditions in the second table persisted for several seconds with the engine under load.
Slobo2712
xantia_v6 wrote: 29 Nov 2019, 06:18 Were the screen-shots above taken with the engine under load, or just free-revving? I would expect an error code for low boost to be thrown if the conditions in the second table persisted for several seconds with the engine under load.
First screen shot is under load,second is car not drive but with load.I have tested these parameters when driving,they are strange..sometimes turbo pressure is same as reference,and sometimes pressure is higher than reference..Is it possible that catalyst is oil dirty or same thing with turbo part which vacum moves,dont know name..?Tnx
