1.6 Hdi broke down now running but no power
Ian Stan
Hi good people
I’m trying to get to the source of a problem for my daughter’s boy friend’s Scudo van , I’m a competent home mechanic who has built a car from scratch and fitted it with Suzuki Motorbike throttle bodies with attendant aftermarket Ecu .
The scudo broke down and wouldn’t run properly let alone drag itself along, RAC diagnosed EGR and abandoned it . I fitted a new cheap EGR and it made no difference but once it warmed up it would at least idle but no response from the throttle at all , mechanic friend loaned me a basic fault code tablet to read the obd. Only fault that came up was glow plug fault . Tried blanking EGR and instantly started , idled from cold and would static rev to 2500 rpm , would pull itself down the road at up to 25 mph in 3rd. Fault codes then suggested MAF . So bought a new one , and fitted today . Car is no better and still no power . Any suggestions gratefully received . Does have a bit of injector blow by on no 4 but that’s been there a while I’d imagine . The van is 58 reg and shows 115000 km on the clock no service history I can find.
- x 6945
Re: 1.6 Hdi broke down now running but no power
I would suggest 'unblanking' the EGR as the engine ECU will likely throw up other faults as a result. Replacement EGRs usually need reinitialising when replaced depending on engine.
Ian Stan
Thanks Mark
I think I’ve tried every permutation , and when I first fitted the EGR my code reader gave me the option of “learning” its’ settings , this changed the problems but didn’t cure them ,the biggest single advance was blanking it off , but thanks.
- x 3296
Hi Stan, and
to the forum. Might I ask that you post up the VIN here (it will be obscured so only Forum staff can read it). Then the Moderators can look up your vehicle, what parts are correct, and the correct procedures for initialising them (if needed).
- x 6945
@James: it's a Fiat Scudo a VIN is irrelevant in this case.
Also this Forum has a policy of not entering into discussions regarding the crippling of engine emissions equipment as it's illegal for road vehicles in the UK (see A7 of our Acceptable Usage Policy: https://www.frenchcarforum.co.uk/forum/ ... hp?t=56502)
All I will say is that although I can't help with Fiat branded vehicles for parts, cheaper parts are well-known to be DOA or of simply inferior quality. You may find the vehicle runs fine for a while with the EGR as you have it, but the engine management ECU will likely start throwing up errors. Blanking it off will only increase NOx emissions and fuel consumption. It's far better to try and locate the source. The intake manifold maybe be clogged up or you may have a problem with the solenoid electrovalves or the vacuum system (depending on your year and engine) for example.
Unfortunately, there's probably not a lot we can do here - although some of the Dispatch and Relay vehicles have Fiat collaboration and share engines, they often need a special S1279 module for the PSA Lexia interface to read and work with some of the engine and other ECUs on these vehicles.Ian Stan wrote: 02 Nov 2019, 00:52 Thanks Mark
Ian Stan
Thanks " Give me a break" I understand your concerns for forum policy , and though common knowledge may refute your fuel consumption theory , I agree common knowledge also backs up your cheap parts advice . I'm just trying to get some progress towards finding a solution . I have retained the Valeo EGR and original MAF as neither seem to be the root cause . Also understand your VIN predicament even though the van was built alongside the PUG and citroen versions and is physically only different in badge and minor styling tweaks , I know there are Fiat forums but I felt the PUG/Cit would have greater depth of experience with the HDI causing the problem . I don't expect miracles but somebody may be able to throw some light on the sudden demise of this one . Thanks for all comments so far
doctle
- x 223
Did you check the basics like fuel filter etc?
Oh buggle
Onlinemyglaren
- x 5672
You might try cleaning the MAF. There is a dedicated MAF cleaner. I used carburettor cleaner, two shots did the trick. The MAF was only two years old and a genuine VDO one (spinoff from Siemens). It has been fine since, around four years now.
- x 6945
By increasing fuel consumption, I mean that the engine without the EGR will take longer to warm up and seal, thereby using more fuel until the engine is at temperature - hope that clarifies.Ian Stan wrote: 02 Nov 2019, 18:15 Thanks " Give me a break" I understand your concerns for forum policy , and though common knowledge may refute your fuel consumption theory , I agree common knowledge also backs up your cheap parts advice . I'm just trying to get some progress towards finding a solution . I have retained the Valeo EGR and original MAF as neither seem to be the root cause . Also understand your VIN predicament even though the van was built alongside the PUG and citroen versions and is physically only different in badge and minor styling tweaks , I know there are Fiat forums but I felt the PUG/Cit would have greater depth of experience with the HDI causing the problem . I don't expect miracles but somebody may be able to throw some light on the sudden demise of this one . Thanks for all comments so far
Normally I would be able to help you with some detail on any fault codes shown - as I relate these specifically to each engine management ECU as they can have slightly different meanings and parameter / reference values depending on system. The engine ECU can instigate a back up mode for any number of faults until they are resolved and this will limit engine power amongst other things to reduce engine / system damage. For engine power loss there should almost certainly be a fault code logged and that is what we normally ask for to save guessing - but completely understand why you thought of asking here.
Ian Stan
Yes changed that early on , thanks though
Ian Stan
Did try cleaning with brake cleaner , made no difference so changed it and still no difference , but thanks.myglaren wrote: 02 Nov 2019, 19:15 You might try cleaning the MAF. There is a dedicated MAF cleaner. I used carburettor cleaner, two shots did the trick. The MAF was only two years old and a genuine VDO one (spinoff from Siemens). It has been fine since, around four years now.
Ian Stan
Tried disconnecting various things, best result came from unplugging the circled plug , van would then rev quite freely up to 2500 as before and haul down the road sluggish in 4th up to about 35-40 mph. Another observation, though could be spurious , when reading all the various parameters on the android code reader, the last reading was water temp at -40 degrees C (minus 40) gauge on the dashboard was working fine, would it get a signal from the Ecu ? Or is the gauge independently analogue signaled
Ian Stan
Will a later Gen Scudo/ Partner with the 1.6 have a DPF ?
Ian Stan
Unplugging the map sensor gives a flat reading of 988.24 mbar and engine rev's freely, connect and it rev's erratically depending on pedal position between 800 and 945 mbar(ish)
