Citroen C5 2009 EGR valve
Sufii
x 3
Re: Citroen C5 2009 EGR valve
Post by Sufii » 22 Oct 2019, 22:29
Thank you very much. I also need the connector, do you thin Citroen sell that sepratly?
x 1681
Post by GiveMeABreak » 22 Oct 2019, 22:37
The connector on the end is the sensor (to the left on the picture above).
Here is the sensor on its own that Citroen do not sell:
sufi 3.PNG (42.62 KiB) Viewed 77 times
Sufii
x 3
Post by Sufii » 22 Oct 2019, 23:02
No, you misunderstood. I meant the connector , with the cables behind.
x 1681
Post by GiveMeABreak » 22 Oct 2019, 23:20
The connectors to the sensors will be part of the engine harness:
This is the main engine harness: 6569TQ is the part for the harness (1)
Sufii
x 3
Post by Sufii » 30 Nov 2019, 13:58
Now I purchased used fuel pressure sensor. But unfortunately I cut the old one from the harness long time ago. This new one have different colours on the cables. How do I connect it right?
x 1681
Post by GiveMeABreak » 30 Nov 2019, 16:00
Hi Sufii.
Ok, so the colours are not important as PSA used anything going! What's important are the pin outs.
sufii pressure sensor.PNG (13.51 KiB) Viewed 30 times
Wire pin outs:
Pin 1: 6774 (Line Pressure Signal) This goes to pin G3 in the engine ECU
Pin 2: 6773 (Line Pressure - Supply) This goes to pin C4 in the engine ECU
Pin 3: 6772 (Line Pressure + Supply) This goes to pin B4 in the engine ECU
The Engine ECU connection should be a brown 48 pin connector.
