Daughter has a Megane C+C , 1.6 VVT, 2006.
Had a new clutch yesterday, plus wishbones.
Needs a rear spring, new tyres and tracking - the steering wheel is off-centre.
Also passenger door mirror and window don't work - they did when she bought it.
The tyres fitted are 205/50 R16 and ZR16 91 W.
I'm getting lots of conflicting info based on registration number, year and model.
Does anyone know if the correct info is given anywhere on the car like Citroens do with a sticker in the door shut with tyre sizes, pressures, paint code and RP#?
Don't have access to the car today. Not that there is a rush as it can't be done until the 30th.
Megane tyres
Onlinemyglaren
- x 5672
Megane tyres
Reason: Corrected Title to Megane
- x 6945
Re: Megane tyres
As you can see Steve, from the info you provided - it has listed 195/65 R15 in red as the defaults - but under that has brought up the correct alternatives - and I suspect it's because of the options so specs / upgrades available.
They are supposed to be like this inside driver door....
But from what I've heard they are often missing or plain wrong!
Onlinemyglaren
- x 5672
Re: Megane tyres
Thanks Marc - it is very confusing. Oponeo has some options but hard to say what is best. Current tyres appear to be way above spec for load and speed, the wheels she has aren't listed.
I am pleased with my Sailun tyres and may try to get them to suit, otherwise probably Toyo.
Onlinemyglaren
- x 5672
Re: Megane tyres
Just a moan but open to suggestions.
She had a new clutch fitted, old one slipping. After a bit she said it smelled of burning (the old one had too.
Took it back, presuming a dud release bearing.
It was the flywheel that had worn in the middle, leaving a narrow contact area around the circumference.
Unfortunately the garage owner went to India the day I took it in. Dropped in a couple of days later and they showed me the flywheel and they were attempting to get a scrapyard replacement, which has proved to be difficult, the one thy did manage to get was too big.
Renault list them but can't supply them NFP.
Mister Auto seems to have some but probably not the right one, prices between £300 & £700
Spoke to the garage owner, back from India and he has asked if I know of anyone who can skim the old clutch. I do know of one workshop near here, will try and contact them but have an unmissable appointment tomorrow, another day down the drain.
She is getting a bit agitated now, into the third week. At least she has a car from work.
Onlinemyglaren
- x 5672
Re: Megane tyres
She got it back on Monday, had to skim the flywheel as no compatible ones available. Only an 06 reg too.
4cvg
Re: Megane tyres
I just joined the forum & realise that something would already be fitted but I hope that it wasn't Sailun. My concern with these would be wet grip. For that matter, I'd be wary of almost any Toyo as well on the same grounds.
I'd be fitting the best tyres possible in the size (best for wet grip under braking & laterally & with benign, non-snappy, limit behaviour). People sometimes say that fussing beyond the minimum is a waste of money as they drive sedately but that response ignores the emergency swerve &/or brake in the wet. At such times, I'd want my tyres to be part of the solution, not the problem.
205/50-16 is a size that is blessed with a number of good tyres.
Pick of them (on the above criteria) are Continental's PremiumContact 6 & Bridgestone's Turanza T005. The former handles more responsively & the latter is more comfort orientated.
Each is about £90 each.
Generally on tyres, I recommend browsing the magazine tests at
https://www.tyrereviews.com/Article/
cheers! Peter
cheers! Peter
Onlinemyglaren
- x 5672
Re: Megane tyres
A couple of months ago I was called out to assist, she had a puncture, no spare of course and no mobile tyre fitters to come on a Sunday.
Tried inflating it and it wasn't having it. Whipped it off and took it to ATS, only place open anywhere near, other than KF opposite.
Only one they had in was £199. Expensive puncture - sidewall was completely trashed.
They had loads of Sailun tyres in stock, none the right size.
Her boyfriend then wrecked that same tyre two days later. Got a part worn for £40.
4cvg
Re: Megane tyres
Just noticed that you are Washington, USA based.
The US is an abysmal place to try to get tyres that are decent in the wet. Best I can offer in your size is Sumitomo's HTR A/S PO2 or Hankook's Ventus V2 Concept 2 (in that order). Not great tyres but . . . . .
Onlinemyglaren
- x 5672
Re: Megane tyres
Not quite correct, it is Washington in England, where the Washington family that spawned George came from originally.4cvg wrote: 06 Jun 2021, 13:31 Just noticed that you are Washington, USA based.
I don't have the C5 any more and when the tyres on the current Civic expire they will be replaced with Sailun tyres.
4cvg
Re: Megane tyres
I stand corrected. You have access to better tyres then. Not that Sailun are among them. Bonne chance! - A source of my concern is the wet braking result for one of their better tyres; see:
https://www.tyrereviews.com/Article/202 ... g-Test.htm
Onlinemyglaren
- x 5672
Re: Megane tyres
I have used them for years after seeing a test track video of their snow tyres and have been very pleased with them. They have been every bit as good as their far more expensive counterparts.
4cvg
Re: Megane tyres
One final remark & then I'll leave it. Best guide to "in extremis" behaviour is the published comparative tests. Not much on Sailun but what there is is contrary to any claim of equivalent performance (see braking test reference above).
I hope that your enthusiasm for them is not tested by an emergency.
cheers! Peter
cheers! Peter
Michel
Re: Megane tyres
Tyre comparisons should be taken with somewhat of a pinch of salt as it’s also very vehicle dependent. What is perfectly fine on one car may be garbage on another..
Example.
My first MX5 had Pirelli P6000s on it , all very good, all correct pressure. I drove it round a quickish bend that I’ve driven round literally 1000 or more times, in the wet and wrote it off when the back simply let go.
My second MX5, I put Avons ZV3s on. They we’re apparently not as good in the wet as those Pirellis.
I went round the same bend, in the wet at higher speed many times without a problem.
My Puma also had Pirelli P6000s when I got it. In anything other than dry conditions, it understeered like a dog on lino.
Example.
4cvg
Re: Megane tyres
You are correct that what works well for one vehicle might not work as well for another. A major factor is the so-called slip angles at which the tyres in question operate. To some extent a tyre's slip angle is modifiable by tyre pressure & my advice has always been that, when changing the tyre type on a given vehicle, one should play around with the front/rear tyre pressure differential. What's "correct" isn't the same for all tyre types. In this case, I hypothesise that the more tautly structured P6000 (operating with a lower slip angle than the Avon) would have benefited from relatively lower front type pressures.
Anyway, the best guide that one has to tyre performance remains the spread of tyre tests, carried out with different vehicles, in different sizes & with different test protocols. Perfect? No. But as good as is available. I consider "feel" & limit behaviour to be very significant for both ordinary non-driving enthusiasts & enthusiasts & the tests I take most note of are those with a substantial subjective appraisal section.
cheers! Peter
cheers! Peter
