Toolbag Tales-Homemade and improvised tools
x 5673
Re: Toolbag Tales-Homemade and improvised tools
Found the Citroen specific one, used on the GS rear hub nuts.
Was ineffective as the nuts are , it the words of Sir Jim, Biblically Tight.
Discovered the official method was to smash them off with a cold chisel and fit new C-nuts and hex nuts and wind them up as tight as possible with the tube spanner - or a socket that I couldn't afford at the time.
Other one and key fob for scale, although some of my dad's tools would dwarf it.
Re: Taps and Dies
NewcastleFalcon wrote: 27 Aug 2019, 18:38 I need an M10x1
Put me onto "Tracy Tools" from Devon, and reckoned I would only need a cheaper one at around £5 for my purpose, and they were excellent at shipping and would sell the taps singly. l
Tracy Tools come up with the goods next day, within 24 hours of ordering....first class literally.
nf own work
nf own work
x 5673
Not an improvised tool as such.
I was just reading a little about Linda Ronstadt - her whole Wiki page is far too long to read in its entirety and I have difficulty listening and reading but did spot this snippet:
Her mother Ruth Mary, of German, English, and Dutch ancestry, was raised in Flint, Michigan. She was a daughter of Lloyd Groff Copeman, a prolific inventor and holder of many patents. Copeman, with nearly 700 patents to his name, invented an early form of the toaster, many refrigerator devices, the grease gun, the first electric stove, and an early form of the microwave oven. His flexible rubber ice cube tray earned him millions of dollars in royalties
I may have his original here - gave the modern one away as I will never use it.
Disc Removal for the desperate.....
Step 1 Cut two slots with an angle grinder
Step 2.  Wedge a screwdriver/cold chisel in the top slot and hit with a hammer
Worked yet again for me today
x 3296
A trick I have been told (for driven disks) is to undo all of the bolts (so the only thing holding the disk in place is rust), start the engine, put the car in gear (first), and then hit the footbrake. The shearing action should break one of the disks free. Put the car in neutral and turn the engine off. Secure the loosened disk (with the wheel bolts), start the engine again, put her into reverse, and repeat. It should break the other disk loose. This cannot work on disks that are on 'free' wheels.
Obviously the car has to be properly supported, and when the disks come loose it can make a bit of a pop. I have NOT tried this for myself, but I have not (as yet) encountered disks that are so securely rusted in place. When I have changed brake disks I had smeared copper slip grease onto the wheel hub before fitting the disk, so that it should not rust hard into place.
x 1746
Some discs (and drums) also have a couple of threaded holes between the main studs/bolt-holes, into which bolts can be inserted, and tightened down, thus pushing the disc/drum away from the hub. If this doesn't make it pop off, with the bolts well tightened down, clout the disc/drum with a lump hammer, and the impact should spring the disc/drum off.
The same threaded holes can be used to squirt some WD/PlusGas into the rusty gap between disc/drum and hub.
A little gem from Peter originally posted up on POTD.
Peter.N. wrote: 23 Sep 2019, 18:13 Image
This is my state of the art high tech tracking tool, been using it for 30 years +, good every time. 8-)
and here's a bit of tool improvisation from me.
Bit of creativity to get this out. Hex none existant so its Mole Grips. No decent bench or vice and some torque required to remove from its rusty hole so out come the socket set extension bars...3 of them joined together, poked up the Hole of the sawn off exhaust pipe to brace the force of the mole grips, and the centre tube of an axle stand over the handle of the mole grips for leverage. Worked.
NF Own Work
NF Own Work
doctle
x 223
Unread post by doctle »
Can anyone work out what this homemade tool is for?
Oh buggle
x 8126
Maybe for lining up capping on the top of a wall? :) Place longer leg against wall face with shorter leg level with capping and then position cap against shorter leg? :-D
doctle
x 223
Its for pressing in the back axle bushing on a Mk3 vw golf. Nasty little bugger to get in. Needs must when the devil fits a bush on a Saturday evening without the proper tools
Oh buggle
doctle
x 223
mickthemaverick wrote: 24 Sep 2019, 21:39 Maybe for lining up capping on the top of a wall? :) Place longer leg against wall face with shorter leg level with capping and then position cap against shorter leg? :-D
Ingenious suggestion!
Oh buggle
The end product to post number one on this thread.
A timing belt tensioner tool for a 2.0Hdi
nf own work
nf own work
regards Neil
Shear Head Bolts
Any accumulated wisdom or top tips on removing shear head bolts?
This type of thing, which you will come across should you ever wish to remove an ignition barrel from the steering column (for a legitimate purpose of course!) like renewing the ignition switch which has nigh on impossible access problems to the screws retaining it without removing the barrel.
They are purposely designed so that the Cutting a "slot in the top" and using a screwdriver is hampered in that they are recessed just enough to make grinding with a dremmel likely to slice into the steering column at the same time
x 3565
If the head has already broken off, then you could try roughening up the remaining 'head' and bond something onto it (JB Weld ??) so you can undo it and just pray that it wasn't done up too tight in the first place.
doctle
x 223
A nut in the earth clamp of a welder then put a spot weld inside the nut. They aren't very tight disconnect the battery before welding
Oh buggle
