C5 X7 2.0 hdi auto electronic parking brake problem
- x 6957
Re: C5 X7 2.0 hdi auto electronic parking brake problem
Sounds reasonable Steve - and the key thing here is that they obviously have experience of repairing these specific units. A no-brainer to me.
- x 6957
If it helps, I will put up the EPB removal / fitting guide for you shortly, just to avoid any potential issues removing it - link below:
C5 X7 Electronic Parking Brake Removal / Fitting Guide
- x 1942
What repair to the EBP might there be in addition to just replacing the cable?
- x 6957
Our Polish friends have undertaken repairs it seems from this link - the pictures show some of the replaved parts:
https://allegro.pl/oferta/linka-hamulec ... 7441098760
From the looks of it, good old reliable plastic gearing again - completely shredded
Unless he's shaven the plastic with the knife in the picture:
- x 1942
If he has a source for replacement plastic gearing then that's quite impressive. OTOH if i's just a cable needed then, if I were in such a position, I'd be doing the rounds of cable manufacturers.
Y Cymro
- x 7
Whilst the car was on the ramp at a Lloyds we managed to remove the cover from the EPB unit. It’s sealed with an adhesive as well as screwed so use of a heat gun was required
Removing the cover allowed the broken cable to be seen and the remaining cables removed so the unit could be taken off the car.
When removed, it could be seen that a retainer supporting the drive screw had broken, potentially allowing misalignment which caused (or helped) the cable to break.
Here’s the drive screw showing the snapped nearside cable. It isn’t a simple matter of unscrewing the hexagon.
Whilst I’m prepared to try our Polish friend I don’t know whether he can repair the housing (I’ve sent photos asking this). The timing is unfortunate as it’s a Bank Holiday so nothing’s going to happen until Tuesday, the MOT expired today and I need the car for holidays on a September 2nd, so I may be forced to buy a Citroen part. C’est la vie as we say in Wales.
On the bright side, I hope the photos and the contact with the Pole will be useful to someone: lincar@op.pl
2013 Citroen C5 Exclusive Tourer, 2.0 HDI Automatic with Techno pack
- x 6957
Crikey, what a mess Steve!
If you're going for an OEM part - give them a call at the earliest (parts usually open before 12 on Saturday), as sometimes they have to order parts in from France directly - so could be a wait there. Or try one of the others I linked to that was slightly cheaper.
- x 1942
That hexagon looks like a crimp holding the inner cable onto a moving part. It's a bit difficult to make out much more as the Photobucket watermark obscures so much!Y Cymro wrote: 23 Aug 2019, 18:39Here’s the drive screw showing the snapped nearside cable. It isn’t a simple matter of unscrewing the hexagon.
Y Cymro
- x 7
Thanks to Myglaren I’ve posted better photos. Should be a little more legible now without the Photobucket ransom watermarkPaul-R wrote: 23 Aug 2019, 18:54 That hexagon looks like a crimp holding the inner cable onto a moving part. It's a bit difficult to make out much more as the Photobucket watermark obscures so much!
Y Cymro
- x 7
The new genuine EPB unit has arrived from Citroen but it has only 2 handbrake cables - which run to the wheels. There isn't included the forward cable which acts as an emergency release. There is a blanking plug in the unit where this cable would be expected.
Can anyone please confirm whether Citroen has done away with the emergency release, or that my existing release should be fitted to the new unit after first removing the blanking plug.
thanks
thanks
- x 6957
Hi Steve - no Citroen have not (and cannot do away with it) - it's integral to the system and is required.
The cable should reconnect to the unit - I will put up some info shortly... - temporarily locked whilst formatting
- x 6957
Procedure for removing and refitting the Electronic Parking Brake in the Citroen C5 X7
Note: Diagbox or a suitable diagnostic tool is recommended to place the handbrake in the removal position (for removing procedure) and again after refitting for the Calibration Procedure.
Removing
Refitting
Refit: The electric secondary brake unit (11).
Tighten the nuts (10) to 0,8 ± 0,2 daN.m.
Connect the connector (at "g").
Refit the protector (9).
Caution: Respect the routing of the manual unlock cable (6) and of the parking brake cables (7).
On each side:
Engage the electrically controlled parking brake manual unlock cable (6) in its housing (at "b").
Immobilise the electrically controlled parking brake manual unlock cable (6) (at "a") ; Using universal pliers .
Couple that handle the (5) to the electrically controlled parking brake manual unlock cable (6).
Refit: The underbody protectors (8) and (7).
Return the vehicle to its wheels.
Refit:
Refit: The glove box (1).
Reconnect the battery.
Caution: Before carrying out the handbrake calibration procedure, ensure that the ferrules of the hand brake cables (7) are correctly positioned in the caliper levers (at "d").
Carry out the electric parking brake calibration procedure, using a diagnostic tool.
Activate the electric handbrake control.
Check the immobilisation of the wheels.
Perform the operations to be carried out following reconnection of the battery.
Removing
- Slacken the parking brake.
- Raise and support the vehicle, with the rear wheels hanging free. (Warning: Refer to correct Lifting Procedure where wheels will be hanging freely:
LDS Tank / Lifting Warning - Place the electric parking brake in the removal position, using a diagnostic tool.
- Disconnect the Battery (danger of automatic re-application during removal procedure)
| Remove the glove box (1). Unclip The gear lever gaiter (2). Remove:
| Pull the handle (5). Immobilise the electrically controlled parking brake manual unlock cable (6) (at "a"), using universal pliers . Uncouple the handle (5) from the electric parking brake manual release cable (6), by means of a screwdriver. |
| Remove the under body protections (7), (8). | Extract the electrically controlled parking brake manual unlock cable (6) from its housing (at "b"). Unclip the electrically controlled parking brake manual unlock cable (6) from the fuel tank (at "c"). |
On each side:
| Remove the protector (9). Disconnect the connector (at "g"). |
| Unscrew the nuts (10). Remove: The electric secondary brake unit (11). |
On each side:
- Position: The handbrake cable (7)
- Clip the guide of the parking brake cable (7) (at "e", "f")
- Couple the parking brake cable (7) (at "d")
- Refit bolt (8) ; Tighten to 0,8 ± 0,2 daN.m
Refit:
- The oddments tray trim (4)
The centre console fascia trim (3)
Y Cymro
- x 7
Thanks Marc
The problem is that the new EPB unit has only the two handbrake cables that run to the callipers, but doesn’t include the “electrically controlled
parking brake manual unlock cable” which runs from the EPB to the glove box (where the emergency manual pull release is connected to it). As the original part had 3 cables then I assumed the replacement should have the same 3 cables - because there doesn’t appear to be a way to connect my original release cable to the EPB unit (I don’t mean connecting the yellow coloured manual pull release in the glovebox to the release cable that runs back to the EPB unit)
I’m wondering whether the Indie has ordered or received the wrong part? I can check the part number with him later. He reckons that Citroen has changed the design and done away with the unlock cable, but that can’t be true as there’d be no alternative way to release the handbrake - with a flat battery for example.
- x 1487
It does look like they have deleted the manual release cable. Here is the latest item on e-bay, showing only the brake cables: EPB Mech
In the parts list it says with the latest unit that you should also take this item: 73
6983 43
01
(MUL) CLOSER
DIAM 10,5 HAUT 15
Which is presumably a plug to put in the hole where the cable no longer is - it's not shown on the parts dia for the handbrake - but I found it on the body blanking dia, item 3:
In the handbook for later cars, there is no mention of the manual release. So it would appear that it is so reliable that it never needs a manual release
And if the battery goes flat, then you're stuffed - unless you chop the cables off and front up another grand to PSA
6983 43
01
(MUL) CLOSER
DIAM 10,5 HAUT 15
- x 1942
I think there must be two ways of releasing the EPB on early X7s. This, now deleted, cable going to the glovebox (which I presume is electronic) and the manual release that you can access at the rear of the centre console, between the two front seats. This is the one that has to be available to use in an emergency.
