Citroen Xsara - Heater Blower NOT WORKING
x 6960
Re: Citroen Xsara - Heater Blower NOT WORKING
Yes VIN, my typo. Leave it with me I have your private message, I’ll check out the wiring diagrams as soon as I can
x 6960
Ok, so I've had a look at your specs and you have Automatic Air Conditioning. Also the blower control module is not separate,so is built onto the blower motor itself - so assume this is what you changed in your earlier post.
The fuse is the F40 in the fusebox that you have checked - so looking at things now I'm wondering if the digital A/C control panel is at fault? I've just changed one on a relative's Picasso for a slightly different problem.
If you have a Lexia, you can run some actuator tests on the climate control panel - i.e. checking that the motor goes through all the speeds, the temperature goes through all the settings, the position o the flap reduction motors etc.
xsara2002hdi
Unread post by xsara2002hdi »
Ok. I’ll need to take it to the local garage. Thx
xsara2002hdi
Another question, the generic ignition switch off eBay works, the car starts etc. The generic switches are ok I assume.
x 6960
I would't even guess at that! If these are faulty or incorrect it can affect the operation of the fan.
belopack
Unread post by belopack »
Hello guys,
my motor and the resistor is good, I tried it by a potenciometer but I cant controlled in the cocpit. I measured the voltage levels in the socket the yellow and the orange wire but it didnt changed when I turn the button.
Please help me by a good wire diagram if its possible.
But the most important thing. There is this part somewhere but I dont know where:
Can you help me that where is it?
