Thank you I will do this in the morningmoizeau wrote: 08 Aug 2019, 19:24 Jack each wheel off the ground so that it takes the load off the spring then go round all the joints with a crow bar. Preferably both front wheels at the same time, that removes the load from the anti roll bar.
Front suspension , Drive shaft rebuild, Help
Huskyxantia
- x 794
Re: Front suspension , Drive shaft rebuild, Help
Husky.
- x 6960
Without wanting to cause offence - the words 'rust' and 'bucket' spring to mind
I think you have done well up to this point keeping it going, but it does seem like you are having lots of component failures in a short space of time. Maybe she's wanting to join the other ZXs in the sky!
Huskyxantia
- x 794
To be honest this car has out done all the more up todate piles I've had, and the caliper issue is simple it was just location or source and last night I found it so today any min now job and weather permitted it a be sorted , as for rust she's sound .GiveMeABreak wrote: 08 Aug 2019, 21:24 Without wanting to cause offence - the words 'rust' and 'bucket' spring to mindI think you have done well up to this point keeping it going, but it does seem like you are having lots of component failures in a short space of time. Maybe she's wanting to join the other ZXs in the sky!
I've seen a couple of hatch backs on one for sale there not as clean as what mine is.
I've spent money on the old car which is cheaper than buying another car that could potentially have shed loads of problems as you get to learn from it , no one seems to be honest when they sell cars (used)
But the old man I got this from was as honest as the day
Husky.
- x 6960
Ok, good luck with it then - I take it you've had a squiz at the thread with the chap I PMd you about with the ZX parts?
Huskyxantia
- x 794
Sure have we've arranged something and I can't thank you enough for all your help.GiveMeABreak wrote: 09 Aug 2019, 09:47 Ok, good luck with it then - I take it you've had a squiz at the thread with the chap I PMd you about with the ZX parts?
As with my rattle sound the slider lock nuts didn't have washers so I've place some I had in my bits n bobs box and its taken the free movement , while I had the wheel off it also gave me the chance of changing the old bottom hose which had a nice shaved piece of rubber sliced out of it, all done now .
Husky.
- x 6960
Sounds painful! But I'm glad it's all fixed.
Huskyxantia
- x 794
All good from this mornings rolling around on the ground , its hard getting back up when your not 20 ish anymore hahahaaa.....Huskyxantia wrote: 08 Aug 2019, 21:14Thank you I will do this in the morningmoizeau wrote: 08 Aug 2019, 19:24 Jack each wheel off the ground so that it takes the load off the spring then go round all the joints with a crow bar. Preferably both front wheels at the same time, that removes the load from the anti roll bar.
Husky.
Huskyxantia
- x 794
This is one car that makes me smile.
I'd love to get a mk1 xantia 1.9d but
For now I'm more than happy with this old bus.
Husky.
- x 6960
She is looking rather sparkly! I had a work colleague with an Advantage - she loved it, but changed it for a new Xsara HDi (needed reliability for work travelling).
Huskyxantia
- x 794
I've had the xsara car and estate both 1.4iGiveMeABreak wrote: 09 Aug 2019, 16:56 She is looking rather sparkly! I had a work colleague with an Advantage - she loved it, but changed it for a new Xsara HDi (needed reliability for work travelling).
Was a nice comy ride.
Husky.
Huskyxantia
- x 794
Cars still driving well !
The other knocking from the front was lose brake caliper. Sorted with new spacers and the correct tightness.
Husky.
Doo
- x 121
I've seen me getting some bearings out by asking nicely and they simply fall out...then you get the job that you think will be easy and you're there for a month
A job like yours, I've ended up using my Dremel to cut a slot into the bearing carrier after having removed the circlip and trying (and failing) to pull, push, hammer and inventing new swear words. But the Dremel cut the slot and the damn thing was tapped out in seconds.
Good luck fella
Good luck fella
Has anyone seen the plot?
Huskyxantia
- x 794
Thanks may have to invest in a Dremel watching folks on YouTube they do seem to be used a lot.Doo wrote: 24 Sep 2019, 20:23 I've seen me getting some bearings out by asking nicely and they simply fall out...then you get the job that you think will be easy and you're there for a month![]()
Good luck fella![]()
Husky.
Huskyxantia
- x 794
Update ....
The car is still going strong and a pleasure to drive just did a 74 mile round trip on about £3 worth of diesel at a steady 65 mostly B roads .
It will take a heck of a car to replace this old bus , why do we get old why do we suffer failing joints chronic gut problems and memory issues I've at last found my old faithful and me as a human are falling to bits
Husky.
