Front suspension , Drive shaft rebuild, Help
Huskyxantia
x 912
Re: Front suspension , Drive shaft rebuild, Help
Unread post by Huskyxantia »
moizeau wrote: 08 Aug 2019, 19:24 Jack each wheel off the ground so that it takes the load off the spring then go round all the joints with a crow bar. Preferably both front wheels at the same time, that removes the load from the anti roll bar.
Thank you I will do this in the morning
:-D
x 6945
Without wanting to cause offence - the words 'rust' and 'bucket' spring to mind :( I think you have done well up to this point keeping it going, but it does seem like you are having lots of component failures in a short space of time. Maybe she's wanting to join the other ZXs in the sky!
Huskyxantia
x 912
GiveMeABreak wrote: 08 Aug 2019, 21:24 Without wanting to cause offence - the words 'rust' and 'bucket' spring to mind :( I think you have done well up to this point keeping it going, but it does seem like you are having lots of component failures in a short space of time. Maybe she's wanting to join the other ZXs in the sky!
To be honest this car has out done all the more up todate piles I've had, and the caliper issue is simple it was just location or source and last night I found it so today any min now job and weather permitted it a be sorted , as for rust she's sound .
I've seen a couple of hatch backs on one for sale there not as clean as what mine is.
I've spent money on the old car which is cheaper than buying another car that could potentially have shed loads of problems as you get to learn from it , no one seems to be honest when they sell cars (used)
But the old man I got this from was as honest as the day
:-D
x 6945
Ok, good luck with it then - I take it you've had a squiz at the thread with the chap I PMd you about with the ZX parts?
Huskyxantia
x 912
GiveMeABreak wrote: 09 Aug 2019, 09:47 Ok, good luck with it then - I take it you've had a squiz at the thread with the chap I PMd you about with the ZX parts?
Sure have we've arranged something and I can't thank you enough for all your help.
As with my rattle sound the slider lock nuts didn't have washers so I've place some I had in my bits n bobs box and its taken the free movement , while I had the wheel off it also gave me the chance of changing the old bottom hose which had a nice shaved piece of rubber sliced out of it, all done now .
:-D
x 6945
Sounds painful! But I'm glad it's all fixed. :)
Huskyxantia
x 912
Huskyxantia wrote: 08 Aug 2019, 21:14
All good from this mornings rolling around on the ground , its hard getting back up when your not 20 ish anymore hahahaaa..... :lol:
:-D
Huskyxantia
x 912
This is one car that makes me smile.
I'd love to get a mk1 xantia 1.9d but
For now I'm more than happy with this old bus. :-D
The ole car
The ole car
The ole car
The ole car
:-D
x 6945
She is looking rather sparkly! I had a work colleague with an Advantage - she loved it, but changed it for a new Xsara HDi (needed reliability for work travelling).
Huskyxantia
x 912
GiveMeABreak wrote: 09 Aug 2019, 16:56 She is looking rather sparkly! I had a work colleague with an Advantage - she loved it, but changed it for a new Xsara HDi (needed reliability for work travelling).
I've had the xsara car and estate both 1.4i
Was a nice comy ride.
:-D
Huskyxantia
x 912
Cars still driving well !
The other knocking from the front was lose brake caliper. Sorted with new spacers and the correct tightness.
:-D
Doo
(Donor 2022)
x 121
Unread post by Doo »
I've seen me getting some bearings out by asking nicely and they simply fall out...then you get the job that you think will be easy and you're there for a month :roll:
A job like yours, I've ended up using my Dremel to cut a slot into the bearing carrier after having removed the circlip and trying (and failing) to pull, push, hammer and inventing new swear words. But the Dremel cut the slot and the damn thing was tapped out in seconds.
Good luck fella 8-)
Has anyone seen the plot? :?
Huskyxantia
x 912
Doo wrote: 24 Sep 2019, 20:23 I've seen me getting some bearings out by asking nicely and they simply fall out...then you get the job that you think will be easy and you're there for a month :roll:
Good luck fella 8-)
Thanks may have to invest in a Dremel watching folks on YouTube they do seem to be used a lot.
:-D
Huskyxantia
x 912
Update ....
The car is still going strong and a pleasure to drive just did a 74 mile round trip on about £3 worth of diesel at a steady 65 mostly B roads .
It will take a heck of a car to replace this old bus , why do we get old why do we suffer failing joints chronic gut problems and memory issues I've at last found my old faithful and me as a human are falling to bits
:shock: #-o :rofl2:
:-D
