Mk1 Xantia boost pressure
kiwifrog
Just wondering if anyone knows what the turbo boost pressure is supposed to be at certain revs for the diesel mk1 ? It seems to be a bit down on power and the turbo was going to be my first check.
Stewart(oily)
- x 35
Re: Mk1 Xantia boost pressure
It depends on load as much as engine speed, when I fitted a boost gauge to a 1.9 TD in standard trim I saw a maximum of approximately 13 psi climbing a hill flat in 4th gear.
kiwifrog
Cool thank you, gives me a ball park figure, someone out there must have more info.....
Timmo
- x 168
from memory it is standard at 12/13psi, there are a few threads on the various peugeot forums about xud tuning, 12/13 psi comes up A Lot as a standard figure, 18psi is easily obtainable through some simple adjustments,
if down on power i'd probably start at the boost hoses??
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
kiwifrog
OK thanks, according to my manual there's a low pressure turbo model and a standard turbo??
Stewart(oily)
- x 35
I believe some estate models were low boost in order to improve economy, there were also some non intercooled ones.
kiwifrog
Gets more confusing, according to my other manual there's 4 x1.9 turbo models
1.9 turbo XUD9 TF
1.9 non turbo XUD9 A
1.9 turbo ( light pressure) XUD9 SD
1.9 turbo ( cat & EGR) XUD9 BTF
1.9 turbo XUD9 TF
- x 3298
If you were to post up the VIN (which will be obscured so only Moderators can read it) a Moderator can look up what your car had when she rolled out of the factory.
kiwifrog
Its NewZealand new if thats any use...
- x 6947
There is very little data I have on this, except that you have a 1.9 TD (XUD9TE) engine. The Turbo part number (new) is no longer available bit was part: 96157189. The exchange Turbo part number is: 95668928, again not available from Citroen. Both are listed as Garrett KKK.
So at least you have some part numbers to go on, But there should also be a sequence of code numbers stamped onto the turbo itself which may prove useful in sourcing a spare or for getting repair quotes of further info.
kiwifrog
Just realized I put a non turbo in my list of turbo models Doh !
