Mk1 Xantia boost pressure
kiwifrog
Post by kiwifrog » 14 Jul 2019, 05:56
Just wondering if anyone knows what the turbo boost pressure is supposed to be at certain revs for the diesel mk1 ? It seems to be a bit down on power and the turbo was going to be my first check.
Stewart(oily)
x 13
Re: Mk1 Xantia boost pressure
Post by Stewart(oily) » 18 Jul 2019, 10:56
It depends on load as much as engine speed, when I fitted a boost gauge to a 1.9 TD in standard trim I saw a maximum of approximately 13 psi climbing a hill flat in 4th gear.
kiwifrog
Post by kiwifrog » 18 Jul 2019, 11:40
Cool thank you, gives me a ball park figure, someone out there must have more info.....
Timmo
x 51
Post by Timmo » 24 Jul 2019, 10:55
from memory it is standard at 12/13psi, there are a few threads on the various peugeot forums about xud tuning, 12/13 psi comes up A Lot as a standard figure, 18psi is easily obtainable through some simple adjustments,
if down on power i'd probably start at the boost hoses??
kiwifrog
Post by kiwifrog » 24 Jul 2019, 19:58
OK thanks, according to my manual there's a low pressure turbo model and a standard turbo??
Stewart(oily)
x 13
Post by Stewart(oily) » 26 Jul 2019, 02:01
I believe some estate models were low boost in order to improve economy, there were also some non intercooled ones.
kiwifrog
Post by kiwifrog » 26 Jul 2019, 06:57
Gets more confusing, according to my other manual there's 4 x1.9 turbo models
1.9 turbo XUD9 TF
1.9 non turbo XUD9 A
1.9 turbo ( light pressure) XUD9 SD
1.9 turbo ( cat & EGR) XUD9 BTF
NOT Alistair or Simon
x 736
Post by Hell Razor5543 » 26 Jul 2019, 07:43
If you were to post up the VIN (which will be obscured so only Moderators can read it) a Moderator can look up what your car had when she rolled out of the factory.
kiwifrog
Post by kiwifrog » 26 Jul 2019, 08:47
Its NewZealand new if thats any use...
x 1672
Post by GiveMeABreak » 26 Jul 2019, 11:00
There is very little data I have on this, except that you have a 1.9 TD (XUD9TE) engine. The Turbo part number (new) is no longer available bit was part: 96157189. The exchange Turbo part number is: 95668928, again not available from Citroen. Both are listed as Garrett KKK.
So at least you have some part numbers to go on, But there should also be a sequence of code numbers stamped onto the turbo itself which may prove useful in sourcing a spare or for getting repair quotes of further info.
kiwifrog
Post by kiwifrog » 28 Jul 2019, 05:06
Just realized I put a non turbo in my list of turbo models Doh !
