Front suspension , Drive shaft rebuild, Help
x 6948
Re: Front suspension , Drive shaft rebuild, Help
Here's your shopping list, don't forget to take your Amex Platinum Card with you. :-D
RefPart NoDescription
13646 53FRONT SWIVEL PIN (Left)
13647 53FRONT SWIVEL PIN (Right)
2330785Wheel Hub
316 144 476 80WISHBONE FRONT (OEM) LEFT
316 144 477 80WISHBONE FRONT (OEM) RIGHT
316 357 731 80WISHBONE FRONT (Dealer Alternative) LEFT
316 357 732 80WISHBONE FRONT (Dealer Alternative) RIGHT
416 072 952 80FRONT TRIANGLE ARM BALL-JOINT: DIAM 16
6335016FRONT HUB BEARING (OEM)
616 239 483 80FRONT HUB BEARING (Dealer Alternative)
73345 35(MUL) STOP RING: 85,4X77,2-2,5
8362307SWIVEL BALL PIVOT PROTECTOR
9692396(MUL) HEX HEAD CAPSCREW: 10X150-50
10362254FIXING BOLT: 10X150-72
11352254(MUL) HEX HEAD CAPSCREW: DIAM 12X175-95 (no longer available)
121803T7(MUL) FLANGED SCREW: DIAM 10X150-80
136925F1(MUL) FLANGED SCREW: DIAM 8X125-16
14352250FRONT SWIVEL PIN BALL-JT SCREW: DIAM 10X150-32
16362230(MUL) SELF LOCKING NUT: IAM 10X150-12,6-16
17352255(MUL) SQUARE NUT: 12X175 (no longer available)
31694677(MUL) PLAIN WASHER: 10X20-2
324010H4(MUL) PLAIN WASHER
336936E1(MUL) FLANGED NUT: M10X150
Huskyxantia
x 927
Unread post by Huskyxantia »
Gonna need a large bag for that lot too lol
Thanks so much
:-D
Huskyxantia
x 927
A few hours over 2 days a bit of blow tourch wd40 other brands are for sale and my bearing kit ... Final ready for a new bearing.
Thank you all whom helped this really is a fantastic club..
Got my sticker today and that made me smile.
End result
End result
Then to this
Then to this
Started like this
Started like this
:-D
x 6948
I saw the mortar hammer there, but no sign of the pneumatic drill... :-D Looks like your having fun anyway.
Huskyxantia
x 927
I was absolutely knackered by the time it was out .
My next query is regarding the road wheel bolts .
Correct me if I'm wrong should these look like chrome type ? One was damaged not sure if the bolt got damaged by the incident which happened the other week.
If i was to get new ones where would i get these and what should i look for ?
Think there 19mm
:-D
x 6948
Your original bolts (as fitted at factory) is part 540535 (DIAM 12X125-53)
Your original wheels should be steel.
Pack of 2 original OEM bolts here for £7:
https://www.ebay.co.uk/p/Peugeot-205-Wh ... 1542123506
x 1497
I've pulled a few bearings using one of those kits - certainly get a sweat on by the time it is out!!
moizeau
x 423
Unread post by moizeau »
Front wheel bearings....what fun. I cheat, do the tedious time consuming removal of the hub then take the hub to the local mechanic and give him 20 euros for about 20 mins work with his 10 tonne press and hot-plate. Half an hour after getting there I'm leaving with a hub that's ready to fit. No swearing, no blood, all knuckles and fingers intact.
Pete
Huskyxantia
x 927
It almost came to that believe me.
:-D
Huskyxantia
x 927
Changed the rear shocks today .
Old ones took over an hour to rise after being taken off the car .
New hub carrier with complete bearing and hub was just collected for the local post office that will be fitted tomorrow .
Once again a massive thanks to all here that helped me, no doubt I'll be back asking questions and stuff..
Getting to really love this old zx estate am I mad ?
:-D
x 3298
Mad? No. Crazy? Probably, but aren't we all?
moizeau
x 423
When your done with repairs.....is it for sale? I need to replace the BX.
Pete
x 2006
Unread post by Stickyfinger »
I would cut that bearing with a dremel rather than press it out.
Huskyxantia
x 927
moizeau wrote: 12 Jul 2019, 18:24 When your done with repairs.....is it for sale? I need to replace the BX.
No not yet , just got it back on the road ,all what I'm doing is due to a pinch bolt failing on the lower ball joint, the company whom sold it are playing the out of warranty card, considering it only did 800miles the photo says it all really,
Spot the difference
Spot the difference
:-D
Jim66a
x 9
Unread post by Jim66a »
If you have a welding set, put a run of weld around the outer bearing race(where the bearings would have run) The heat will shrink the race and if it doesn't fall out, It will require only light taps.
