| Ref | Part No | Description |
| 1 | 3646 53 | FRONT SWIVEL PIN (Left) |
| 1 | 3647 53 | FRONT SWIVEL PIN (Right) |
| 2 | 330785 | Wheel Hub |
| 3 | 16 144 476 80 | WISHBONE FRONT (OEM) LEFT |
| 3 | 16 144 477 80 | WISHBONE FRONT (OEM) RIGHT |
| 3 | 16 357 731 80 | WISHBONE FRONT (Dealer Alternative) LEFT |
| 3 | 16 357 732 80 | WISHBONE FRONT (Dealer Alternative) RIGHT |
| 4 | 16 072 952 80 | FRONT TRIANGLE ARM BALL-JOINT: DIAM 16 |
| 6 | 335016 | FRONT HUB BEARING (OEM) |
| 6 | 16 239 483 80 | FRONT HUB BEARING (Dealer Alternative) |
| 7 | 3345 35 | (MUL) STOP RING: 85,4X77,2-2,5 |
| 8 | 362307 | SWIVEL BALL PIVOT PROTECTOR |
| 9 | 692396 | (MUL) HEX HEAD CAPSCREW: 10X150-50 |
| 10 | 362254 | FIXING BOLT: 10X150-72 |
| 11 | 352254 | (MUL) HEX HEAD CAPSCREW: DIAM 12X175-95 (no longer available) |
| 12 | 1803T7 | (MUL) FLANGED SCREW: DIAM 10X150-80 |
| 13 | 6925F1 | (MUL) FLANGED SCREW: DIAM 8X125-16 |
| 14 | 352250 | FRONT SWIVEL PIN BALL-JT SCREW: DIAM 10X150-32 |
| 16 | 362230 | (MUL) SELF LOCKING NUT: IAM 10X150-12,6-16 |
| 17 | 352255 | (MUL) SQUARE NUT: 12X175 (no longer available) |
| 31 | 694677 | (MUL) PLAIN WASHER: 10X20-2 |
| 32 | 4010H4 | (MUL) PLAIN WASHER |
| 33 | 6936E1 | (MUL) FLANGED NUT: M10X150 |
Front suspension , Drive shaft rebuild, Help
- x 6947
Re: Front suspension , Drive shaft rebuild, Help
Here's your shopping list, don't forget to take your Amex Platinum Card with you.
Huskyxantia
- x 927
Gonna need a large bag for that lot too lol
Thanks so much
Thanks so much
Husky.
Huskyxantia
- x 927
A few hours over 2 days a bit of blow tourch wd40 other brands are for sale and my bearing kit ... Final ready for a new bearing.
Thank you all whom helped this really is a fantastic club..
Got my sticker today and that made me smile.
Husky.
- x 6947
I saw the mortar hammer there, but no sign of the pneumatic drill...
Looks like your having fun anyway.
Huskyxantia
- x 927
I was absolutely knackered by the time it was out .
My next query is regarding the road wheel bolts .
Correct me if I'm wrong should these look like chrome type ? One was damaged not sure if the bolt got damaged by the incident which happened the other week.
If i was to get new ones where would i get these and what should i look for ?
Think there 19mm
Think there 19mm
Husky.
- x 6947
Your original bolts (as fitted at factory) is part 540535 (DIAM 12X125-53)
Your original wheels should be steel.
Pack of 2 original OEM bolts here for £7:
https://www.ebay.co.uk/p/Peugeot-205-Wh ... 1542123506
- x 1496
I've pulled a few bearings using one of those kits - certainly get a sweat on by the time it is out!!
moizeau
- x 423
Front wheel bearings....what fun. I cheat, do the tedious time consuming removal of the hub then take the hub to the local mechanic and give him 20 euros for about 20 mins work with his 10 tonne press and hot-plate. Half an hour after getting there I'm leaving with a hub that's ready to fit. No swearing, no blood, all knuckles and fingers intact.
Pete
Huskyxantia
- x 927
It almost came to that believe me.
Husky.
Huskyxantia
- x 927
Changed the rear shocks today .
Old ones took over an hour to rise after being taken off the car .
New hub carrier with complete bearing and hub was just collected for the local post office that will be fitted tomorrow .
Once again a massive thanks to all here that helped me, no doubt I'll be back asking questions and stuff..
Getting to really love this old zx estate am I mad ?
Husky.
- x 3298
Mad? No. Crazy? Probably, but aren't we all?
moizeau
- x 423
When your done with repairs.....is it for sale? I need to replace the BX.
Pete
- x 2003
I would cut that bearing with a dremel rather than press it out.
Huskyxantia
- x 927
moizeau wrote: 12 Jul 2019, 18:24 When your done with repairs.....is it for sale? I need to replace the BX.
No not yet , just got it back on the road ,all what I'm doing is due to a pinch bolt failing on the lower ball joint, the company whom sold it are playing the out of warranty card, considering it only did 800miles the photo says it all really,
Husky.
Jim66a
- x 9
If you have a welding set, put a run of weld around the outer bearing race(where the bearings would have run) The heat will shrink the race and if it doesn't fall out, It will require only light taps.
