Hi all,
Got a problem with the rear fog light on my ZX 1.9D estate, the lens was smashed and has completely come off.
Just need help on how to remove the light unit and hopefully where to get one? Tried Citroen dealer and local breakers but no joy.
Are there any other vehicles or models that share the same rear fogs? On my estate they are right underneath in the bumper.
Any help would be appreciated as I have got MOT next month.
Many thanks
Danny
Citroen ZX rear fog lens
- x 6957
Re: Citroen ZX rear fog lens
Left or Right? RHD / LHD?
6350C0 is the left hand Citroen part number. Magneti Marelli Part number is: 08187
Available part here: https://www.ebay.co.uk/itm/Rear-fog-lig ... 3438648049
6351C0 is the right hand Citroen part number. Magneti Marelli Part number is: 08188
https://www.ebay.co.uk/itm/Retronebbia- ... ctupt=true
dannyboy84
Hi,
Many thanks for the fast reply.
It is a P reg so I think 1997? RHD
Do you know how to remove them, any tips or tricks? I don't want to break anything.
Thanks again mate, really appreciate it
Regards
Danny
Regards
Danny
- x 6957
Just a tip - you will get better results looking for parts, using the Magneti Marelli part numbers as they are made by them. Those in the links have them in stock, but many of the searches I did for the Citroen Part Numbers were all out of stock / no longer available.
As for removing: Look at item 3 in the diagram below. To the left side of the lamp you can see a clip, so using a trim removal tool, you should be able to gently push in on the side of the clip and lever it out at an angle. Re-insertion should be a matter of putting the other side in at an angle and swinging the other side back into place. There are no official details I have on removing them, but I believe this is the correct way.
Pug_XUD_KeenAmateur
- (Donor 2018)
- x 228
not familiar with it personally, but having bought the new light as links already provided, the method of fitting will become a whole lot clearer from looking at the new part.
I'd imagine its gonna be a 'pop the rear wheel off, set up a decent light and reach in' job. Maybe pop the spare wheel out if its a Cradle type on those (don't recall) to make some extra room.
Ensure its safe before you get under there, you'd only have a ton of car fall on you once!
Puxa
- x 6957
If memory serves you should be able to disconnect the wiring plug once you have swung out the lamp. I'm sure you'll let us know though!
dannyboy84
Thanks guys again, you are so helpful, will get the part first and do as suggested, once I've done it will let you all know on here.
Regards
Danny
Regards
Danny
- x 1750
Seeing that link, Mark, to Magneti Marelli light fittings, I had a delve into their sizeable on-line catalogue yesterday, to see whether any other Citroen light fittings might lurk there (eg XM front sidelights). Entirely forgot that a good few Citroen fittings of that era were Valeo (how could I have forgotten that?
), and therefore nix (for XM) there. Was ZX an exception then?
- x 6957
Here's just a few vehicles they supplied lamp units for Chris - Indicator light for XM was one - but was shared with other models.
C8
Berlingo
Relay
Xsara & II
C3 Pluriel & C3
C6
Dispatch I & II
Xantia II
XM II (632545 - Indicator light)
ZX
Synergie
Saxo
C4 Picasso
C8
Berlingo
Relay
Xsara & II
C3 Pluriel & C3
C6
Dispatch I & II
Xantia II
ZX
Synergie
Saxo
C4 Picasso
- x 6957
I've just uploaded Magneti Marelli's latest catalogue for light fittings, which makes it a little easier:
Magneti Marelli Lighting Catalogue 2017-18
- x 1750
Aha! The ubiquitous side indicator repeater light!
That explains why those are so easy to find on various sites.
dannyboy84
Hi guys,
Have to tried get hold of the rear lights and can't, was refunded money from eBay because not in stock and have tried other online places where you can order it but then says stock unavailable or discontinued.
Anybody know anywhere abroad or anybody breaking a ZX estate or have seen one on a breakers recently?
There easy to remove by the way, spring clip on boot lid side push in and pull out.
Many thanks
Danny
Many thanks
Danny
dannyboy84
Hi guys
Got the car through the Mot.
Swapped the nearside rear fog to the offside as this is all that is legally required by law. That's what the garage did anyway
Will keep a lookout for one in the future, thanks for the help everyone
Regards
Danny
Regards
Danny
