Aisin Tf-80 / AM6 Oil Change Questions (Mini-Guide Page 4)
moizeau
x 429
Re: Aisin Tf-80 / AM6 Oil Change Questions (Mini-Guide Page 4)
Unread post by moizeau »
Have a look here https://www.tecmotor.fr/huile-transmiss ... four-stars . Make sure yours uses 3309 and not the later one, is it JW1? It should say on a sticker in the engine bay. It's a fuel economy / environmental regulation depending on age of vehicle thus the Euro 4/5 category.
Pete
barbrady
Unread post by barbrady »
I couldn't find sticker with relevant information in the engine bay.
I know the Mobil1, but the mannol most cheaper, that's why I asked opinions.
x 6955
What's your VIN?
barbrady
Sloppysod
x 386
Unread post by Sloppysod »
milleplod wrote: 24 Jul 2017, 11:31
I tried not to show my disappointment....but he spotted me sobbing in the corner! :lol:
Yep, I spoke to the dealer in Mansfield a few weeks ago - they quoted me....wait for it....£600+!! :shock: That was for the full (7 ltrs?) amount of fluid, presumably Citroen-branded stuff, and obviously their extortionate labour costs.
I'm now back to thinking I'll just sell the car if I start getting any symptoms, seems less hassle tbh!
Pete
This is a good quote, as, I am not sure I have read it on FCF or esle where, but there is someone out there, calculated that to change the whole 7 liters of oil you need you need a large number of drain/fill cycles, for example each drain/fill action will replace around 51% of the dirty oil. to replace most of the dirty oil you are probably looking at arleast 5 or 6 drain/fill cycles at about 3 litres each cycle which looks about 15 to 18 litres of oil ++++ - I think they told you wrong I think they should have said we will flush 7 litres through you gearbox.
And..........I asked my local dealer for some Genuine Citroen oil and the price was over £40 a litre!! - special stuff see :rofl2: Just bought 6 litres of Total LV (AW-1 Spec) for £40 :-D as I plan on doing another change either this or next weekend.
Barbrady - you are looking for markings like these
Labels on Gearbox AM6 (AW-1) fluid
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6955
Ok, the rule is:
  • EURO 5 engine: AW-1 oil
  • EURO 4 engine: JWS 3309 ESSO oil
So your engine is Euro 4 so JWS 3309.
Don't get confused with "Level 5" referred to on the VIN specifications - which is purely a PSA reference and not the same as the Euro Standards.
barbrady
It seems this sticker is under the air filter house. Isn't it?
x 6955
The identification 'Plate' is riveted to the Gearbox casing here:
  • "a" :Automatic gearbox type AISIN
  • "b": Automatic gearbox type PSA
  • "c": Identification marking
  • "d": Serial number
There is an identification label attached to the ECU here:
  • "e" :Date of manufacture
  • "f": Homologation number (PSA)
  • "g": ECU no. (PSA)
  • "h": Bar code (PSA)
  • "j": Gearbox no. (PSA)
  • "k": Bar code (AISIN)
  • "l": Serial number
barbrady
GiveMeABreak wrote: 26 Mar 2019, 19:29 Ok, the rule is:
It means, this oil is good for it. Anybody knows Mannol products?
https://www.ebay.co.uk/itm/OEM-TUV-GERM ... 3145774526
x 6955
That should do fine (and it's made in Germany).
EDC5
x 130
Unread post by EDC5 »
barbrady wrote: 26 Mar 2019, 20:08
For the same money you can get the genuine Mobil ATF 3309:
https://www.ebay.co.uk/itm/Mobil-ATF-JW ... Sw5cNYG31o
moizeau
x 429
Or use the link I supplied above, 51 euros for 7 litres, so €7,30 a litre.
Pete
barbrady
Thaks for everybody, but I can get 1 liter Mannol for 3,75 EUR here in Hungary. So the difference is significant.
moizeau
x 429
Would you like to say where from?
Pete
barbrady
Of course. But the language is hungarian :)
https://alkatreszek.hu/atf_multivehicle_1l_metal_ko
