Citroen synergie 2002 speedometer problem
tony1976
Morning forum I have just acquired a 2002 Citroen synergie 2.0 hdi which has a speedometer problem in as much as there are no actual total miles showing in the display but trip counter works. When you hit the trip reset button it seems to kill the whole speedometer and nothing works for around 10 mins.
Any help or advice would be grateful
- x 6956
Re: Citroen synergie 2002 speedometer problem
We'll need a VIN, there are different models with different displays - some with 4 dials, some with 5.
tony1976
vin VF7**************[VIN obfuscated, can be read by forum staff]
thank you in advance
GiveMeABreak wrote: 23 Mar 2019, 09:37 We'll need a VIN, there are different models with different displays - some with 4 dials, some with 5.
- x 6956
Perfect. So this is a Synergie Family Saloon 2.0 HDi 110 (DW10ATED) with manual gearbox 5.
Is the speedometer needle moving according to speed? Is the speedo needle intermittently failing or erratic? If it is then likely to be the speedo cable or either of the end connections possibly worn.
This should be your display:
tony1976
Hi the needles seem to be working as they should i think.
the speed needle and rev needle seem ok i think.
it's just the digital display that does not show any actual miles but the trip shows how many you have actually covered.
as soon as you touch the trip reset button it knocks everything out.
- x 6956
Ok, so it may very well be a faulty connection inside the instrument display panel or the display component itself. Unfortunately, given the age of the vehicle, I do not any wiring diagrams for this model.
tony1976
Hi Marc,
thank you for all your help
would you have a part number for the speedo at all so i can look at the dreaded flea bay for a replacement
- x 1056
Its not just the bulb behind the milometer blown is it?
On the Synergie/Dispatch when the bulb goes you can barley see the display.
tony1976
Hi Marc I don’t think so as the trip is nice and bright
tony1976
I’ve had a quick look on flea bay none about only Peugeot ones and some ulysse ones I doubt very much they would fit
- x 6956
There are no separate control units, only the complete instrument panel. The part number is 6101YC (of course no longer available from Citroen), but shared with the 806 from the same era.
None I can find, but these claim to have one in stock for an 806 with the same part number:
http://www.peugeotparts.co.uk/page1.htm
I can't see it being the tachometer (speed control) unit, or you would have speedo issues which you say are fine. I would be tempted to take the unit cover off and make sure all the connections are nice and tight and that there are not loose wires or plugs first of all.
Reason: Correct my Part Number Typo
- x 6956
Here's how to remove it:
| Remove the fuse board access trap for access to the fixing (1). | Remove:
Remove the bottom cowl (3). |
Remove:
| Remove the mountings (7). |
Refitting N.B.: Check that the neck (9) which guides the speedometer cable is correctly positioned.
tony1976
been on the website you recommended all i can see are these, however the part number you suggested is "The part number is 6010YC" is this a typo or am i looking at the totally wrong one?
6101TF 306 INSTRUMENT CLUSTER 1
6101YC 806 INSTRUMENT CLUSTER 0
6101YE 806 INSTRUMENT CLUSTER 0
6101YY 806 INSTRUMENT CLUSTER 0
- x 6956
Apologies my Bad! Too much going on.
The Part number should of read 6101YC. I have corrected my original post now.
Here is the link again with the search enabled on this part number - just do a CTRL F and type the part number to locate it on the web page.
http://www.peugeotparts.co.uk/page18.htm
tony1976
They must have just sold it as they are showing 0 available.
i will keep looking though thank you So much
