How to remove this panel/cover?
atr
x 6
Unread post by atr »
I would like to remove the panel/cover shown in the picture attached. my attempts so far, yield nothing. there must be some "trick" to remove it. hope that you can help. it is at the back of the center console, under the rear cigarette lighter socket.
Thanx.
Avi
x 6955
Re: How to remove this panel/cover?
It doesn't come off on its own Avi - you have to remove the whole central console as a symmetrical operation. I'll dig out a guide shortly.
x 6955
Instructions for Central Console Removal C5 X7 (Automatic Gearbox Only)
Move the front seats as far back as possible.
Unclip: The assembly (10) ( as "n" ); Using Trim Removal Tools.
Disengage the assembly (10).
Disconnect the connector ( as "p" ).
Remove the assembly (10).
Remove:
The audio system
The air conditioning control ( automatic )
Unclip: The glove box (11) ( as "q" ); Using Trim Removal Tools [1].
Remove the glove box (11).
Unclip: Front panel (12) (Central console (/) ) ( as "r" ); Using Trim Removal Tools.
Detach: Front panel (12) (Central console (/) ).
Disconnect the connectors ( as "s" ).
Remove: Front panel (12) (Central console (/) ).
Remove the bolts (14) (Central console (13) ).
Slide the front seats as forward as possible.
Electric seats:
  • Reconnect the battery
  • Slide the front seats as forward as possible
  • Disconnect the battery
Unclip the blank ( 15) (Central console (13) ) ( as "t" ); Using Trim Removal Tools (Symmetrical operation).
Remove the blanking piece (15) (Central console (13) ) (Symmetrical operation ).
Remove bolts (16) (Central console (13) ) (Symmetrical operation ).
Intentionally Blank
Open the central armrest.
Unclip the diagnostic socket ( as "w" ).
Detach:
  • The diagnostic socket ; Through the central console (13)
  • The centre console (13) (Towards "u" then "v" )
  • Disconnect the 12 V socket connector ( as "x" ).
  • Remove the central console (13).
Intentionally Blank
Refitting
CAUTION: Correctly position the front seatbelt stalks to refit the centre console.
Proceed in the reverse order to removal.
Tighten:
  • The bolts (6), (14) to 0,4 ± 0,25 daN.m
  • The bolts (8), (16) to 0,5 ± 0,25 daN.m
  • Reconnect the battery.
  • Check that the electrical equipment is working correctly.
atr
x 6
Thanx Marc. I never thought that it's so complicated, I think that I'll pass. do you happen to know if there is a way to pull out the black compartment above this panel - the one that contain the rear cigarette lighter?
Avi
x 6955
I'll check shortly, but just in the middle of posting up the tow bar electrics fitting instructions on the other thread.
x 6955
No, nothing on that - the rear 12V socket connector is removed from inside when you have the panels off. The black part is the housing and is part of the overall structure from what I can see.
Jetik
Unread post by Jetik »
Hi Guys,
If we are talking about dismantling of panels. I would need to remove this side plastic panel of passenger front electric seat (on the picture) on my C5 X7. Does anybody have instructions how to do it?
Jan Rohar
x 6955
Here you are:
Unclip the side trim (1) at "a" using trim removal tools.
Disconnect the connectors at "b", "c".
Remove the side trim (1).
Unclip the trim (2) at "d".
Remove the trim (2).
Jetik
Thanks a lot, Marc.
JR
alos_21
Unread post by alos_21 »
Hi everybody, howto remove this cover?
x 6955
You need to lift and roll back the carpet (2) at the rear to expose the trim clips (a). Remove these to remove the trim or expose the other clips if you need to remove the inner trim.
CitroenC5Perth
Unread post by CitroenC5Perth »
atr wrote: 18 Mar 2019, 13:47 I would like to remove the panel/cover shown in the picture attached. my attempts so far, yield nothing. there must be some "trick" to remove it. hope that you can help. it is at the back of the center console, under the rear cigarette lighter socket.
Thanx.
Avi
I was wanting to remove the same panel on my 09 C5, so that I could access the cable to the 12 volt system. I found that there is no need to remove the entire console nor undo any bolts. it simply prises off with a flat head screw driver. Unclip from the top and then from both sides along the crease line.
Huskyxantia
x 874
Unread post by Huskyxantia »
GiveMeABreak wrote: 18 Mar 2019, 14:28 It doesn't come off on its own Avi - you have to remove the whole central console as a symmetrical operation. I'll dig out a guide shortly.
Hi Marc , is there a guide for the console removal regarding a c3 picasso as i may have to swap out the pedals and bar . Thanks. Im not finding much regarding either so if there is something to help it would be useful
, thanks
:-D
Huskyxantia
x 874
Huskyxantia wrote: 05 Dec 2024, 21:47
, thanks
Dont need it now sorted it myself.
:-D
