Xsara Picasso Idling
Post Reply
Vuk1987
My Cars: Citroen Xsara Picasso
Post by Vuk1987 »
I'm sorry for writing off topic, but I didn't want to start a new one. I have minor issues when idling my Xsara Picasso 1.6 16V petrol engine ( I think it's NFU engine series ). I doesn't turn off normally, but when my wife (she is a beginner driver ) presses the gas pedal harder and then releases it the car turns off. Then it turns off on idle until I give it a little ride, then its all fine again. I need help locating ICV, so I can give it a try by cleaning it.
And yeah, if anyone has any recommendations of where could I get some car schematics (software, pdf manual, printed manual ) in order to locate components easily, I would appreciate it.
Reason: Split into a New Topic
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5742
Re: Xsara Picasso Idling
Post by GiveMeABreak »
It's not off topic, but doesn't belong on the XM Thread, so I have moved your post into a new Topic.
Can you clarify your post as it doesn't quite make sense - the bit in bold.
...presses the gas pedal harder and then releases it the car turns off. Then it turns off on idle until I give it a little ride, then its all fine again
You'll have to search for or purchase manuals, we don't provide these, but we do have some free mechanics guides, of which there are several for the Xsara Picasso:
viewtopic.php?f=3&t=61218
We can help with parts diagrams, but you'll need to provide your VIN and specify the part you are looking for.
Also, I'm not sure what you mean by an "ICV"? Maybe it has has been lost in translation?
picassodad
My Cars: pug306, citroen picasso
x 14
Post by picassodad »
what year and engine?? i have some info but not much. Look on here and there may well be a system diagram to show whats there, but not where it is on the car.....i'm still trying to find the double relay and inertia switch !
check the basics like the main earth lead from the body to the engine as on pug 306's they can break due to engine movement and cause problems......
admin are brilliant with exact info and diagrams etc., extremely helpful.
I friend has a 1.6 and that misbehaved, needed 2 new exhaust lambdas and the idle stepper motor, the thread had gone in that.
Vuk1987
Post by Vuk1987 »
I'm sorry you had to waste time creating new subject. I'll respond to everything, I just need to go to work right now.
C15 Romahome White
CX 20 Polar White
x 5742
It's no problem, just update us when you get the chance. :)
Vuk1987
Post by Vuk1987 »
First, thank you for the handbook.
What I meant was that car turns of on itself when idle, so I have to keep gas pedal pressed in order to keep him running on idle. When I drive for a few minutes (1st gear, start, 2nd gear, 3rd gear, driving 2 minutes ... ) and then idle again, everything is fine, it doesn't turn off on idle, but if one would press the gas pedal when idling (no movement, clutch pressed or neutral gear ) and then releases it, the problem would most often appear again. By ICV I meant "idle control valve" but I see that you are using the term "idle stepper motor" . To be honest, I don't even know what kind of idle regulation this car has, since I've bought it half a year ago. My old Opel Vectra (Cavalier MK3 in the UK) just had a motorized butterfly valve (literal translation from Serbian language).
My VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Engine number is: NFU10FX6PPSA3110165
Picassodad year is 2006, and thank you for the advice.
C15 Romahome White
CX 20 Polar White
x 5742
So for the benefit of others, the OP has a 2007 XSARA PICASSO FAMILY SALOON 1.6 i 16v 110 (TU5JP4) Petrol with Manual gearbox 5.
C15 Romahome White
CX 20 Polar White
x 5742
I've heard of a similar problem and changing the idle stepper hasn't made any difference.
I did come across this little bit of advice which seems to have worked for several owners, so won't cost anything to try!
  • Start with engine off
  • Turn key so car on but not engine...leave for 10 seconds
  • Turn off for 10 seconds
  • Turn on again (not engine) this time with foot fully on gas for 10 secs
  • Start engine with foot fully on gas for 2 seconds then release foot...
Then it should run fine....resets what it needs to.
Vuk1987
Post by Vuk1987 »
Thank you for the advice. I’ll try it, and post about the results
Vuk1987
Post by Vuk1987 »
Unfortunatley it didn’t work. So, if anyone would know the location of an idle stepper motor I’d apreciate if he could share it with me. I want to give it a try by cleaning it
Vuk1987
Post by Vuk1987 »
It also smells like faulty oxygen sensor to me ...
Vuk1987
Post by Vuk1987 »
Turned out it was elecronic throttle control device , motor to be specific. I went to repair shop and they’ve replaced it. I’m mad because I couldn’t figure out it was the problem. I surely would have try to fix it.
C15 Romahome White
CX 20 Polar White
x 5742
I've only just had time to see your last posts - but glad you have it sorted now. Was it the accelerator potentiometer they replaced?:
Vuk1987
Post by Vuk1987 »
No, it was assemby of butterfly valve with motor.
I’m sorry, I can’t find the exact english expression for that part right now :)
picassodad
x 14
Glad you have it fixed but do you have the old part? and what failed with it??
Post Reply
