My turn for a C5!
x 3281
Re: My turn for a C5!
Post by Hell Razor5543 »
Thanks for both the info and the VIN details, Marc.
Michel
Post by Michel »
Yes it is.
Vacuum pipe is what you need.
Could be the vac solenoid that's duff.
I'll show you where it is and where the vac pipe is if you are around in light sometime
x 3281
Well, how about New Years' Day (after we have all recovered from the merriment of the night before)?
Michel
Post by Michel »
Hell Razor5543 wrote: 26 Dec 2018, 23:07 Well, how about New Years' Day (after we have all recovered from the merriment of the night before)?
As a strict non-drinker I'll have nothing to recover from. I intend getting up at about 6am and taking advantage of the quiet roads and ride down to the coast - Portsmouth, have a brew and some breakfast and ride back :)
I'd guess I'll be home by about 11am!
x 8181
Post by CitroJim »
I'm running a double-header parkrun on New Year's Day and than I'll be doing what you will be doing Mike, more or less, going for a long bike ride and finding a nice cafe somewhere :)
x 3281
Another thing I will be doing in the future is replacing the gearbox oil. I was unable to find any Total BV 75W80, but Total themselves have shown that their Gear 8 oil is suitable for the ML5T 5/1 gearbox;
https://www.total.co.uk/lub-advisor
https://total-gbr.lubricantadvisor.com/ ... 015_en.pdf
I think this is worth knowing, in case anybody is fixated on the BV 75W80 oil.
x 3281
OK, that might explain things.
While it was quiet this morning I had a quick look under the bonnet at the vacuum piping. One of them (after the T join) headed off under the cover for the nearside sphere. After I took the cover off I found something unexpected. That pipe was not connected to anything, and had a bolt in it, blocking it. I don't know what THAT electro valve does, but I shall see what happens when I next take her out for a drive.
Michel
Post by Michel »
Did you connect it to something? It sounds like it could be the EGR that was disconnected...
Marc : can you please provide a diagram of the vacuum hoses on James’ car then we have something to work off when he comes over next week and specify what size of vac pipe it uses?
x 3281
I have connected the pipe to the electro valve that resides under that cover (there was an 'empty' spigot). There are two electro valves close together; one for the turbo, the other for the EGR (but I don't yet know which is which).
I cynically wonder if this had been done to either get some easy (and expensive) 'work', or to devalue the car to reduce the amount of money somebody would have to pay for it, or to mask an expensive fault for when somebody came to buy her. I know I bought it from a trader, but I wonder how much they knew about her.
x 6960
Post by GiveMeABreak »
Here you go - Arthur Itis in the fingers now. :bomb:
ComponentReference
ignition Injection Control unit1
Engine Speed Sensor2
Camshaft Position Sensor3
Water Temperature Sensor8
Accelerator Pedal Sensor9
Vehicle Speed Sensor10
Brake Pedal Switch11a
11b
Clutch Pedal Switch12
Atmospheric Pressure Sensor13
Battery14
Injection Double Relay15
Diagnostic Warning Lamp34
Centralised Diagnostic Socket35
Transponder36
Consumption Information37
Tachometer38
Pre-heating Warning Light39
Pre-post Heat Box40
Pre-heater Plugs41
Cruise Control Switch42
Automatic Gearbox ECU43
Air Conditioning Compressor44
Additional Heating:
Heating Elements (electrical)
Additional Heating
45a
45b
Additional Heater Control Relay46
ComponentReference
Fuel Temperature Sensor6
High Pressure Fuel Sensor7
Fuel Tank16
Fuel Pump17
Fuel Filter
Low Pressure Regulator
18
Fuel Cooler19
Fuel Heater20
high Pressure Fuel Pump21
Fuel High Pressure Common Injection Rail22
Diesel Injectors23
High pressure fuel regulator31
3rd Piston Deactivator on the High Pressure Fuel Pump32
ComponentReference
Inlet Manifold Pressure Sensor4
Air Flow Meter5
Air Cleaner24
Turbocharger25
Air/Air Heat Exchanger26
Exhaust Gas Recycling Valve (EGR)27
Turbo Waste Gate Control Valve28
Recycling Regulation Electrovalve (EGR)29
Turbocharging Pressure Regulation Solenoid Valve30
Exhaust System33
Vacuum Pump47
Throttle Housing Control Electrovalve (EGR)48
Throttle Butterfly Housing (EGR)49
Piping EGR
11628 LQElectro Valve
21628 JZValve EGR
31628 2NPollution Control Circuit Seal
41628 KAGas Recycling Tube
51628 KCExhaust Gas Water Exchanger
Diam 54
61628 KEGas Recycling Tube
81628 KFPollution Control Circuit Seal
91628 PH
NFP
Electro-Valve Bracket
101628 PJ
NFP
141622 V4
NFP
EGR Control Vacuum Pipe
151628 3JTube Collar
Diam 35 A 38 Larg 9
161628 RF
NFP
Support Clip
6t Diam 10-5(5)
174814 66Pipe Fastener Clip
Diam 4,75
706939 97(Mul) Nut With Captive Washer
Diam 6x100-7-18
716930 95(Mul) Stud
6x100-22-16-10
726936 A0Base Nut
6x100-6-10
736913 G9
RP9800644180
(Mul) Chc R D L Screw
Diam 6x100-16
746913 P4(Mul) Chc R D L Screw
Diam 6x100-25
756922 G0(Mul)Self Lock Self-Tap Screws
M 6x100-20
776922 54(Mul)Self Lock Self-Tap Screws
Diam 6x100-20
x 3281
Sorry about putting you to all this effort, Marc.
OK, re-connecting that pipe has not made any difference to her whatsoever. If I scratch my head any more I SHALL end up bald!
x 3281
How much of a vacuum should there be on the vacuum pump (and should it be a smooth or pulsed vacuum)? I checked the pipe was secure on the pump, then I disconnected it and fired up the engine. There IS a vacuum, but it does not seem that strong, and (if the sound is anything to go by) it is pulsed.
x 6960
James, have a look at the mechanics manuals I uploaded
viewtopic.php?f=3&t=61218#p590278
The pressures for the air supply circuit to the butterfly valve / EGR etc are shown there for testing,. There is not a lot of pressure needed at all:
Download the C5 MK I 2004 manual and look on pages 218-219. Your engine is the RHZ variant.
x 3281
Thank you once again, Marc.
x 3281
As mentioned in the "Crotch Rocket" post by Michel, I am going to have to get a nut splitter (and I have ordered one off e-bay for under £6). As the switch is faulty (and I have proven this is the case; two pins through the wires, when touched together, popped open the glass) I decided, yesterday, to replace the tailgate glass switch on the C5. Unfortunately I had not allowed for the possibility that the wiper arm had seized on. I tried too hard to remove it, and have avoidably damaged a couple of things (that I will have to replace; bloody ham-fisted idiot I am!). I have, however, probably found why the heated glass isn't working well; there are signs of damaged wiring. I am not sure if it is something I can repair (not sure if my soldering iron is good enough for that gauge of wiring), so I will either get an auto electrician to fix it or get a replacement one from a scrappy.
I have also found a NEW issue with her (she is biting me and my wallet, but I hope she will stop that soon), in that the N/S/F calliper is binding. I don't know if it is the calliper or the cables. I have contacted PTS, explaining what I know (so far), and she is provisionally booked in for the rear arm bearings, front brakes, vacuum, and bushes. Lesser things (oil change, screen wash pump, and so on) I will do myself.
I know that (with what I have paid for her so far, and the costs in the near future) I probably could have bought a better car. However, I could have spent a few thousand and still bought a lemon. Bearings, brakes and bushes are a long term consumable, and should be good for a few years. Hopefully, once I have got her sorted, she will be good for a long time (barring unforeseen problems such as accidents).
