Remote central locking wire diagram
Good morning , I've just bought a xsara Picasso 02 plate it doesn't have remote central locking just key for doors, i have a hawlk aftermarket kit and was hoping someone could give me advice on the wiring diagram to fit it thanks
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: Remote central locking wire diagram
That doesn't make sense to me, as the Xsara Picasso from its launch in 2000 in the UK had Remote central locking as standard!
You just may not have the remote locking fob that you can order from your dealer that operates it, as these often get lost and not replaced. I really would not bother wrecking the car to fit this - as you could end up causing more problems, due to the multiplexed wiring on the Picasso.
What is the VIN number and I'll be able to confirm this for you, but I'm 99.9% sure it will have.
hi marc thanks again vin. VF7**************[VIN obfuscated, can be read by forum staff]
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
ok, so confirmed that they all have central locking, including yours.
Your version is just before the change to VAN CAN multiplexing. Your remote fob would of looked something like this:
Do you have this type of fob? If not you may have only been passed the other key that looked like this:
Regardless of type, each has a transponder chip incorporated into the fob. The larger fob in the first diagram has the additional circuitry to send the remote locking and unlocking requests to the vehicle.
If you are missing the fob, you can get one ordered from the dealer which will contain a new key blade and remote and they will code it to the vehicle for you.
There are aftermarket suppliers of copies of these fobs, but unless you get the right one you may have issues. Regardless it will need coding to the vehicle using Citroen's software. The part number for your fob is 6490L8 and these are £123.28 inc. VAT from Citroen for the remote fob.
Yes i only have the key in 2nd picture so will look at getting one ordered, thanks for your help today marc
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
No worries, I hope that has saved you from pulling the doors to bits
Indeed dont have time only time for this time of year
