This is something that doesn't really bother me, but from reading another thread, it seems like something I could easily fix.
Problem is that heater speed #3 does not work for each fresh or re-circulated air. #1, #2 & #4 all work as expected.
From the other threads this problem is slightly different, as they report only a single speed is operational. Does this affect the potential cause of my problem?
Like I said, if it was something relatively straightforward, I'll have a bash at it, otherwise I can live with it.
The illumination light for this part of the dash doesn't work either - a smack on the side of the console usually puts it on again, but this is a separate issue.
Heater Issue - Xsara
- (Donor 2021)
- My Cars: Xsara 2.0HDi 90
- x 10
OnlineGiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5739
Re: Heater Issue - Xsara
Given what you mentioned about the lighting too, I would be leaning towards an internal fault of the heater control panel.
Taking it apart and giving it a clean up of the contacts may solve the problem - you could also replace the lighting bulb at the same time (shown as 4 in the diagram (1.2W))
- (Donor 2021)
- x 10
Okay - might try that.
I should have said that position #3 provides the same output as #2 instead of it not blowing.
OnlineGiveMeABreak
C15 Romahome White
CX 20 Polar White
Sounds like the track on the speed dial - but costs nothing to try and clean it up in case it is a contact problem.
