1.6 HDi Injector Bolts
DHallworth
x 163
Unread post by DHallworth »
I'm not sure where to post this as it related to both Citroen's and Peugeot's!
I'm doing some work on our 207 HDi at the moment. See my latest blog post for more of that...
viewtopic.php?f=14&t=29757&p=588938#p588938
Does anyone have the torque values for the 1.6 HDi engine...
Ideally...
Rocker cover bolt tightening sequence and torque values.
Inlet manifold torque values.
Injector studs into head.
Injector clamp bolts onto studs.
Thanks,
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
DHallworth
x 163
Re: 1.6 HDi Injector Bolts
I think I've had a little bit of luck...
The studs I think are 7NM, and the clamp bolts are 4NM + 65 degrees.
Still looking for a tightening sequence and torque figures for the rocker cover though. Chances are it'd be ok when being sensible but it's nice to have a job done properly.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
moizeau
x 429
Unread post by moizeau »
6mm thread is generally 30mn, 8mm 40, it will depend on gasket type etc. Sequence, start from the middle and work out diagonally, but I'm sure you know this.
Pete
x 6963
Here you go David:
Exhaust Manifold Torque Settings
ReferenceDesignationdaNm
(3)Exhaust manifold mounting nuts / Long studs3 ± 0,3
(4)Exhaust manifold mounting nuts / Short studs2,5 ± 0,2
-Fixing studs on the exhaust manifold1 ± 0,2
Tightening Sequence
Cylinder Head Torque Settings
Engine codeDV6ATED4
Engine legislative type9HX
Pre-tighten ( daNm)2 ± 0,2
Tightening ( daNm)4 ± 0,5
Angular tightening (In degrees)260 ± 5°
x 6963
Here's the Injection Data I think you wanted:
ReferenceDesignationStageTightening torque
(4)Diesel injectors fixing pillar screws - Camshaft bearings coversPre-tighten
Tightening
0,5 daNm
1 daNm
(39)The unions on the diesel injectorsPre-tighten
Tightening
2 daNm
2,5 daNm
(40)Injector mounting flange nut / Pillar screws (4) of the camshaft bearing cap castingPre-tighten
Angular tightening
0,4 daNm
75°
(41)Diesel injection pump on supportTightening2,2 daNm
(42)Diesel injection pump pulleyTightening5 daNm
(43)Diesel high pressure pump front supportTightening2 daNm
(44)Diesel high pressure pump rear supportTightening2 daNm
(45)Connector on high pressure diesel pumpPre-tighten
Tightening
2 daNm
2,5 daNm
(46a)Fuel high pressure common injection rail on the engine blockTightening2,2 daNm
(46b)Fuel high pressure sensorTightening4,5 daNm
(47)Fuel high pressure common injection rail unionsPre-tighten
Tightening
2 daNm
2,5 daNm
(48)Fuel filter supportTightening0,7 daNm
moizeau
x 429
Just wondering why the norm is daNm, it's one decimal point, my torque wrenches are in Nm?
Pete
DHallworth
x 163
Hi Mark,
Thanks for that, that's great.
Do you have the ones for the inlet manifold?
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
moizeau
x 429
Have you not got a BOL? I was wondering whether to do without, but no, it's on the shelf.
Pete
DHallworth
x 163
I've not got one that covers the 1.6 HDi unfortunately.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 6963
Can you hang on until the morning? I’ve powered down LCARS for the evening, and am using this hopeless Apple iPad, of which the upgrade is causing stacks of typos! 🤬
x 1909
GiveMeABreak wrote: 18 Oct 2018, 21:35...hopeless Apple iPad...
Words that naturally run together.
DHallworth
x 163
Marc, no rush at all, I'm still waiting for a few parts to arrive in the post anyway :)
Again, thank you very much for your help.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
x 163
Paul-R wrote: 18 Oct 2018, 21:41
I wouldn't be without my 12.9" iPad Pro!!!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 6963
Without going too far :offtopic: , I would still be using my iPad 2 that is still on IOS 9 if it weren’t so slow David, but this iPad Air with IOS 12 is awful.
I’ll get the other bits to you dans le morning.
