I'm not sure where to post this as it related to both Citroen's and Peugeot's!
I'm doing some work on our 207 HDi at the moment. See my latest blog post for more of that...
viewtopic.php?f=14&t=29757&p=588938#p588938
Does anyone have the torque values for the 1.6 HDi engine...
Ideally...
Rocker cover bolt tightening sequence and torque values.
Inlet manifold torque values.
Injector studs into head.
Injector clamp bolts onto studs.
Thanks,
David.
1.6 HDi Injector Bolts
DHallworth
- x 167
DHallworth
- x 167
Re: 1.6 HDi Injector Bolts
I think I've had a little bit of luck...
The studs I think are 7NM, and the clamp bolts are 4NM + 65 degrees.
Still looking for a tightening sequence and torque figures for the rocker cover though. Chances are it'd be ok when being sensible but it's nice to have a job done properly.
David.
David.
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
moizeau
- x 429
6mm thread is generally 30mn, 8mm 40, it will depend on gasket type etc. Sequence, start from the middle and work out diagonally, but I'm sure you know this.
Pete
- x 6957
Here you go David:
Exhaust Manifold Torque Settings
Tightening Sequence
Cylinder Head Torque Settings
| Reference | Designation | daNm |
| (3) | Exhaust manifold mounting nuts / Long studs | 3 ± 0,3 |
| (4) | Exhaust manifold mounting nuts / Short studs | 2,5 ± 0,2 |
| - | Fixing studs on the exhaust manifold | 1 ± 0,2 |
Tightening Sequence
| Engine code | DV6ATED4 |
| Engine legislative type | 9HX |
| Pre-tighten ( daNm) | 2 ± 0,2 |
| Tightening ( daNm) | 4 ± 0,5 |
| Angular tightening (In degrees) | 260 ± 5° |
- x 6957
Here's the Injection Data I think you wanted:
| Reference | Designation | Stage | Tightening torque |
| (4) | Diesel injectors fixing pillar screws - Camshaft bearings covers | Pre-tighten Tightening | 0,5 daNm 1 daNm |
| (39) | The unions on the diesel injectors | Pre-tighten Tightening | 2 daNm 2,5 daNm |
| (40) | Injector mounting flange nut / Pillar screws (4) of the camshaft bearing cap casting | Pre-tighten Angular tightening | 0,4 daNm 75° |
| (41) | Diesel injection pump on support | Tightening | 2,2 daNm |
| (42) | Diesel injection pump pulley | Tightening | 5 daNm |
| (43) | Diesel high pressure pump front support | Tightening | 2 daNm |
| (44) | Diesel high pressure pump rear support | Tightening | 2 daNm |
| (45) | Connector on high pressure diesel pump | Pre-tighten Tightening | 2 daNm 2,5 daNm |
| (46a) | Fuel high pressure common injection rail on the engine block | Tightening | 2,2 daNm |
| (46b) | Fuel high pressure sensor | Tightening | 4,5 daNm |
| (47) | Fuel high pressure common injection rail unions | Pre-tighten Tightening | 2 daNm 2,5 daNm |
| (48) | Fuel filter support | Tightening | 0,7 daNm |
moizeau
- x 429
Just wondering why the norm is daNm, it's one decimal point, my torque wrenches are in Nm?
Pete
DHallworth
- x 167
Hi Mark,
Thanks for that, that's great.
Do you have the ones for the inlet manifold?
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
moizeau
- x 429
Have you not got a BOL? I was wondering whether to do without, but no, it's on the shelf.
Pete
DHallworth
- x 167
I've not got one that covers the 1.6 HDi unfortunately.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6957
Can you hang on until the morning? I’ve powered down LCARS for the evening, and am using this hopeless Apple iPad, of which the upgrade is causing stacks of typos!
OnlinePaul-R
- x 1943
Words that naturally run together.
DHallworth
- x 167
Marc, no rush at all, I'm still waiting for a few parts to arrive in the post anyway
Again, thank you very much for your help.
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
DHallworth
- x 167
I wouldn't be without my 12.9" iPad Pro!!!
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
- x 6957
Without going too far
, I would still be using my iPad 2 that is still on IOS 9 if it weren’t so slow David, but this iPad Air with IOS 12 is awful.
I’ll get the other bits to you dans le morning.
