C2 cranks but no start
paullap
x 6
""""""""""""""fixed"""""""
Unread post by paullap »
Hi Marc, I should practice what I preach, I was suspecting a burnt circuit board in the bsi unit, So I took it out and took it apart, no burnt area's . So I decided to check the fuses while it was on my desk, These are the fuses that my brother swears he had checked, sure enough a 20 fuse had blown, put it all together and it fired up, perfect. many thanks for the help.
Completely my own fault, do not trust anything my brother tells me.
Paul
x 6945
Re: C2 cranks but no start
Excellent - pleased that’s sorted and a cheap repair! I think your brother owes you a pint or two.
x 1939
Asking again.
Paul-R wrote: 16 Oct 2018, 08:19 You say it was falling apart. Was anything done to fix it?
paullap
x 6
The key was falling apart, No i taped it up with insulation tape.
Paul
x 1939
Did it work at all after that?
paullap
x 6
When i changed the fuse
x 1939
Yes but did the car start at all after you taped the key back up?
paullap
x 6
The key was not the problem, The problem was the blown fuse on the BSI module
