Cambelt change on an automatic c5 tourer 2010 2.0 HDI
French_Cars
Unread post by French_Cars »
Hi All,
I am planning to change the cambelt on a 2010 2.0hdi c5 X7 2010 with automatic AM6 box. I need to clarify the following please:
1- Do I need to be in “P” or “N” to align the camshaft?
2- planing to use M8 bolt to lock camshaft, do I need special tool for flywheel lock? do I need to remove starter to find it?
3- is it OK to use impact wrench on crank pulley to undo it? If NO, how to undo the 22mm nut?
4- How to tighten the crank pulley nut? And does it need to be at 70Nm + 62 degrees?
Does anybody have any instructions that might assist in carrying out the cambelt change please?
Thank you in advance for any help.
x 6948
Re: Cambelt change on an automatic c5 tourer 2010 2.0 HDI
Pop your VIN here (it will automatically be masked) and I'll see what I have.
EDC5
x 130
Unread post by EDC5 »
You would have to have the gearbox in N surely. Otherwise you could bust the parking pawl in the gearbox.
x 1476
Unread post by xantia_v6 »
It does not really matter, as the torque converter isolates the engine from the transmission regardless of the gear selected.
EDC5
x 130
^ Very good point! looks like my brain was in the wrong gear making that comment :lol:
French_Cars
GiveMeABreak wrote: 02 Oct 2018, 13:47 Pop your VIN here (it will automatically be masked) and I'll see what I have.
Thanks Marc, the VIN is:
Simple76
x 9
Unread post by Simple76 »
If you buy a gates cambelt kit it will come with a set of instructions.
x 6948
I would certainly recommend one of the kits - there are 2 available from Citroen - one with the belt and pulleys and the other with all that plus the water pump and gasket.
Prices:
Belt & Pulleys - Part No: 0831W1: £162.41 inc. VAT
As above including Water Pump & Gasket - Part No: 1613561780: £209.70 Inc. VAT
ReferenceDesignationTightening Torque
(45)Bolts (Timing Cover)0,5 daNm
(46)Bolts (Cylinder Reference Sensor )0,6 daNm
(47)Bolts (Timing Chain Tensioner)0,6 daNm
(48)Bolts (Roller Tensioner )5,7 daNm
(49)Bolts (Engine Speed Sensor)0,7 daNm
(50)Nut (Roller Tensioner ) (Timing Gear)2,1 daNm
(51)Stud (Roller Tensioner ) (Timing Gear)1 daNm
(52)Bolts (Camshaft Pulley )Pre-tighten to 2 daNm
Angular tightening to 60°
Whilst I'm putting together the 'How To' document for you, here are the recommended tools and their part numbers that will be referenced in the procedure that I will post up shortly:
HDi Plug KitFlywheel StopPeg for Detting Camshaft Pulley
Flywheel Locking ToolBelt ClampPulley Centring Tool
x 6948
C5 X7 (163) DW10CTED4 Timing Belt Procedure
Part One: Ancillary Drive Belt
Tools Used:
Dynamic Tensioner Compression Lever4 mm Dia. Peg
Remove:
  • The protective panel under the engine
  • The front right wheel
  • The front right mud guard
CAUTION: Mark the direction of fitting of the ancillary drive belt if it is to be reused.
Fit the tool [0188-Z] on the dynamic tensioner bolt (1).
Detension the ancillary drive belt (2); Using tool [0188-Z].
Peg by means of tool [0188-Q1] (at "a").
Remove:
The tool [0188-Z]
The accessories drive belt (2)
Checks:
Make the following checks:
  • Confirm the absence of points of resistance, noise and traces of grease on the dynamic tensioner and accessory pulleys
  • Check there is no oil on the accessory drive belt
  • Visually inspect the belt, flexing it slightly to check that it has no splits or cracks on the back or in the grooves
  • Replace any defective parts
Refit the ancillary belt (2), checking that the belt is correctly fitted in the grooves of the different pulleys and if re-using the old belt, ensure that it is refit in the correct fitting direction.
Remove the peg [0188-Q1]; Using tool [0188-Z].
Refit:
Part Two: Timing Belt
Tools Used: Refer to Previous Post
During removal: Plug the fuel low pressure supply pipes; Using the plugs [1617-J].
  • Uncouple the unions of the fuel low pressure circuit (at "a").
  • Unclip and move aside the manual priming pump (1).
  • Remove the mounting of the diesel fuel manual primer pump (2) ; By means of a screwdriver (at "b").
Remove the air union (3)
CAUTION: Use a rubber shim of sufficient surface area to avoid distorting the engine oil sump (Risk of obstruction of the oil pump suction strainer.)
Support the engine using a jack and a soft block (Timing gear side).
Remove:
  • The mountings (4)
  • The bolts (7)
  • The engine supports (5) and (6)
Disconnect the connector of the engine speed sensor (at "c").
Release and move aside the electrical harness (8).
Remove:
  • The pulley cover (11)
  • The bolts (10)
  • The top timing cover (9)
CAUTION: It is essential to rotate the engine by means of the bolt (12) and in the clockwise direction only.
Peg:
  • The camshaft pulley ; Using tool [0188-M]
  • The flywheel ; Using tool [0188-Y]
Lock the flywheel using the retainer [0188-F].
CAUTION: The target (16) must show no trace of damage and no magnetic source must go near it.
CAUTION: Use of an impact wrench is prohibited (Risk of the bolt (12) breaking in the crankshaft)
Remove:
  • The bolt (12) and its spacer
  • The crankshaft pulley (15)
  • The engine speed sensor target (16)
  • The 3 bolts (14)
  • The timing cover (13)
Clean the crankshaft thread with a M14x150 thread cutter.
Unscrew nut (17).
Detension the dynamic tensioner roller (18).
Remove the timing belt (19).
Verification
Check that the following components rotate freely (Absence of play and points of resistance):
  • Dynamic roller tensioner (18)
  • Roller tensioner (20)
  • Crankshaft pulley (21) on keyways
  • Water pump pulley (22)
Visually check:
  • That there is no trace of an oil leak
  • That there are no coolant leaks
  • That there is no rubbing on the timing covers
CAUTION: Replace any defective parts.
Dynamic Roller Tensioner
CAUTION: The operations for replacing and adjusting the tension of the dynamic tensioner roller (18) are performed with the aid of a mirror.
Replacement
CAUTION: Do not release the new dynamic tensioner roller (18) without having refitted the timing belt (19).
Remove:
  • The nut (17)
  • The stud (23)
  • The dynamic roller tensioner (18)
CAUTION: The dynamic tensioner roller (18) should be secured in the cylindrical pin (25).
Refit:
  • The dynamic roller tensioner (18) (new) (Locked)
  • The stud (23)
  • The nut (17) ; Finger tighten
  • Align the eccentric (24) on the axis "d" ; Using a hexagonal spanner
If Re-Used:
Align the eccentric (24) on the axis "d" ; Using a hexagonal spanner.
Refitting:
CAUTION: Adhere to the tightening torques.
Pre-Tightening The Belt
CAUTION: Always replace the timing belt (19).
  • Rotate the crankshaft pulley (21) on its cotter pin; Centre using the tool [0188-AH].
  • Fit the timing belt (19) on the camshaft pinion ; Immobilise the pinion ; Using tool [0188-AD].
  • Position the timing belt (19) on the pulleys in the order indicated ; Span ("e") of the belt correctly tensioned.
CAUTION: New dynamic roller tensioner (18): Take away the locking pin.
Position of the indexState of tension of the timing belt
"f"Dynamic roller tensioner (18) at maximum timing belt tension
"g"Dynamic roller tensioner (18) at nominal timing belt tension
"h"Dynamic roller tensioner (18) at minimum timing belt tension
Apply a maximum tension to the timing belt (19):
  • Do up the nut (17) by hand
  • Rotate the eccentric (24) anti-clockwise
  • Bring the index to position "f"
  • Tighten the nut (17)
N.B. : The eccentric (24) is close to the horizontal.
Remove the tools [0188-AD], [0188-AH].
CAUTION: Systematically replace the screw (12); Do not go beyond 5 minutes between pre-tightening and final tightening of the bolt .
Refit:
  • The 3 bolts (14)
Remove the tools [0188-F], [0188-M], [0188-Y].
Turn the engine 6 rotations in the clockwise direction.
Check the position of the timing belt (19).
Peg the assembly with tools [0188-F], [0188-M], [0188-Y].
Slacken the bolt (12) in order to permit the crankshaft pulley to rotate on its keyways.
Final Tension
CAUTION: When detensioning the dynamic tensioner roller, do not go past the index "g". Otherwise, you must restart the pretensioning operation.
Apply a nominal tension to the timing belt:
  • Slacken the nut (17) while maintaining the eccentric (24) in position
  • Slowly rotate the eccentric (24) in the clockwise direction
  • Bring the index to position "g"
  • Tighten to the specified torque: The nut (17)
Retighten the bolt (12) to the correct torque.
Refit the pulley cover (11) ; Using rubber lubricant
CAUTION: Check the correct positioning of the pulley cover by pulling gently on the lip.
Refit:
  • The bolts (10)
Clip the electrical harness (8).
Connect the connector of the engine speed sensor (at "c").
Refit:
  • The mountings (4)
  • The bolts (7)
  • The air union (3)
  • Remove the diesel fuel manual priming pump support (2) ; By means of a screwdriver (at "b")
  • The manual diesel priming pump (1)
Couple up The low pressure fuel unions (at "a").
Refit the Ancillary Belt.
Refit the Front RH Splash Shield
Refit:
CAUTION: Perform the operations that are required following a reconnection of the ancillaries battery.
Here endeth the lesson. :-D
Simple76
x 9
Seems a good price. Would Citroen not use gates belts originally?.
x 6948
They do, and the one that came off mine was a Gates belt when I recently had the complete kit done on mine at 70k, so the previous was the original one.
moizeau
x 423
Unread post by moizeau »
Not as good a price as this
https://www.piecesauto24.com/gates/7650292
Pete
French_Cars
Pete, that looks reasonably priced, have you actually bought this kit from them? Is it genuine Gates kit?
If so I will order one.
moizeau
x 423
I have ordered from them, and if it's not in stock then an equivalent or better is supplied. I will buy my kit from them along with the filters and oil, though it's not the same kit, slightly older version of the same engine. Dispatched by courier and comes from Germany for 10 euros for me in 3 days.
Pete
x 6948
Guys - just watch the part numbers - there are similar, but different ones depending on engine. I only supply the original Citroen OEM part numbers - so you have the originals to compare - but from what I can see some of those part numbers are not the same.
