C4gp 08 towing kit
bigbill00
C4gp 08 towing kit
Unread post by bigbill00 »
Can anyone tell me if 9428.67 is the correct tow kit for my 08 c4gp
Cheers
x 6945
Re: C4gp 08 towing kit
Again, as per your other 2 posts, we need a VIN to help you. For this query, can you also confirm if you need electrics and towbar?
bigbill00
Ok I have towbar and am looking to fit electrics
Am checking if this is the right fit for my c4gp
Vin VF7**************[VIN obfuscated, can be read by forum staff]*******
Thanks for your help
x 6945
Ok I’ve got that, will look later as I’m just off for an hour now.
bigbill00
Cheers for all your help
x 6945
Ok, so this is the recommended harness. It contains the BSR EV unit (trailer module unit that will talk to the BSI and ABS / ESP system)
Info:
  • Compatible on all the vehicles from start of series; To fit the fuse, consult the additional doc; Harness fitted with a BSR EV; Non-Contractual Photo.
Description
  • Harness supplied with:
  • 1 x 13-pin socket plus fixings;
  • 1 fitting instructions;
  • 1 BSR EV.
Technical Characteristics:
  • Always follow the manufacturer’s instructions and especially the tightening torques indicated in the installation manual.
  • It is essential that the jack be removed from its housing in the spare wheel to be stored in the boot.
  • This harness takes account of the features of the vehicle, thus ensuring safety, reliability and simplicity of fitting.
  • Simple connection using the interface connectors identical to those for the vehicle.
These are the related parts numbers / options that are compatible:
9427 AC: SWAN’S NECK TOWING BALL
9427 AF: TOW BAR WITH TOW BALL THAT CAN BE REMOVED WITHOUT TOOLS
9453 13: (ACC) CARAVAN REAR VIEW MIRROR
Part No: 16062177 80 and costs £126.85 from Citroen inc. VAT.
They recon it is 2.5 Hours to fit the harness (by their estimations)
bigbill00
So the 9428.67 isn't the right one
And the one in the picture 16062177 80 is the right one
If am reading right
x 6945
That's correct - the 942867 is not listed under any part or accessory for your specific C4 Picasso. :-D
bigbill00
Cheers shame only 30 quid
x 6945
The proper one should automatically deactivate rear parking sensors and tell the ABS/ESP ECU that you are towing, so that it can implement a special stability programme for towing. It should also be fully compatible with your car's electronic multiplexed architecture.
