Can anyone tell me if 9428.67 is the correct tow kit for my 08 c4gp
Cheers
C4gp 08 towing kit
- x 6947
Re: C4gp 08 towing kit
Again, as per your other 2 posts, we need a VIN to help you. For this query, can you also confirm if you need electrics and towbar?
bigbill00
Ok I have towbar and am looking to fit electrics
Am checking if this is the right fit for my c4gp
Vin VF7**************[VIN obfuscated, can be read by forum staff]*******
Thanks for your help
- x 6947
Ok I’ve got that, will look later as I’m just off for an hour now.
- x 6947
Ok, so this is the recommended harness. It contains the BSR EV unit (trailer module unit that will talk to the BSI and ABS / ESP system)
Info:
9427 AC: SWAN’S NECK TOWING BALL
9427 AF: TOW BAR WITH TOW BALL THAT CAN BE REMOVED WITHOUT TOOLS
9453 13: (ACC) CARAVAN REAR VIEW MIRROR
Info:
- Compatible on all the vehicles from start of series; To fit the fuse, consult the additional doc; Harness fitted with a BSR EV; Non-Contractual Photo.
- Harness supplied with:
- 1 x 13-pin socket plus fixings;
- 1 fitting instructions;
- 1 BSR EV.
- Always follow the manufacturer’s instructions and especially the tightening torques indicated in the installation manual.
- It is essential that the jack be removed from its housing in the spare wheel to be stored in the boot.
- This harness takes account of the features of the vehicle, thus ensuring safety, reliability and simplicity of fitting.
- Simple connection using the interface connectors identical to those for the vehicle.
| Part No: 16062177 80 and costs £126.85 from Citroen inc. VAT. They recon it is 2.5 Hours to fit the harness (by their estimations) |
bigbill00
So the 9428.67 isn't the right one
And the one in the picture 16062177 80 is the right one
If am reading right
If am reading right
- x 6947
That's correct - the 942867 is not listed under any part or accessory for your specific C4 Picasso.
- x 6947
The proper one should automatically deactivate rear parking sensors and tell the ABS/ESP ECU that you are towing, so that it can implement a special stability programme for towing. It should also be fully compatible with your car's electronic multiplexed architecture.
