GPS antenna
Moderator: GiveMeABreak
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5721
Re: GPS antenna
Ok, so at least you have tried the basic fixes. Let us know how you get on.
- My Cars: Citroen C5 Tourer
Re: GPS antenna
Definetly mate !
Re: GPS antenna
By the way, how can I found this parameter?!?
On Diagbox it has names, but not numbers So I couldn't find it...
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: GPS antenna
That is only to configure the dashboard multifunction screen fo a non-factory fitted option to display navigation instructions. You shouldn’t change anything there for a factory fitted system or you could find you will have no data when you get the unit fixed.
Vborovic was changing from a vehicle with no previous navigation system, so needed to configure his dash correctly.
Re: GPS antenna
Ok, I understand now. Thanks!
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: GPS antenna
No worries, just trying to help you avoid some pain later!
Re: GPS antenna
Hi guys! First of all I would like to thank you for your help and support!
After I spoke with Harman & Becker, they gave me the details of their service partner from Germany. I contacted them and they told me that I must send the unit to them and they will fix it. When I asked about the price, they told me that, apart from delivery costs, there's a 50 euro fee for the diagnose and then depending on what they have to fix.
I spoke with Clarion UK and they told me that they are working only in partnership with a dealer, so I must go to a dealer, the dealer will remove the unit from the car and arrange a collection for Clarion UK. Clarion UK will send the unit to Clarion France to be fixed and then back on the same route to the dealer to be installed back on the car. Regarding the costs, I must speak with the dealer as they will tell me the price. I told them if can send the unit to them but they remind me that they don't work with private persons.
I sent an email to Citroen Hatfield, but they didn't replied until now.
I also sent an email to the spanish company but they didn't replied until now.
So, in the end I bought a RNEG unit from eBay, put it on the car (rewrite the VIN code), install the rneg50b software (as it had rneg20) and it's working fine with 10-12 satellites conection.
For others with the same issue I have the following solutions:
1. You can go to a local dealer and ask for the Clarion service
2. You can get in contact to the German service and send them the unit
3. You can buy another unit
The German service details are:
Albert Kempf GmbH
Brebacher Landstraße 15
66121 Saarbrücken
Telefon: 0049-681-66333
Telefax: 0049-681-67100
E-Mail: service@sc-kempf.de
Internet: http://www.sc-kempf.de
Geschäftsinhaberin (Owner): Elke Kempf
Geschäftszeiten (Business Hours): Montag - Freitag: 08:00 - 16:00
Thank you again for your help and support!
Albert Kempf GmbH
66121 Saarbrücken
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: GPS antenna
Glad you finally have it sorted - the costs of repair are normally expensive and there is generally a minimum charge regardless of the fault.
There can be many faults with these and pinning t down is difficult if there are no codes returned from Diagbox.
You may be able to buy a second hand unit for much less, such as you have done. There's always a risk with that - but hey, that's life!
Thanks for posting the other information up on the repair centre in Germany - I will add it to the other links on the forum.
Re: GPS antenna
Everyone is looking for the costs, so in the end, this was the cheaper solution, in my case.
I didn't put the other service companies details, as it were already in the post. It's good to put them together. Maybe others have realatives in those countries and they can sort it out there. It's good to have more options.
Cheers!
Cheers!
- New User
- My Cars: C5 HDi 138 Exclusive saloon manual 2012 New Look
Re: GPS antenna
Hi! I have the same problem, water ingress on my roof antenna, C5 2012 New Look HDi 138 Exclusive. Upgraded firnmware of the RT6 via Citroen official CD to 2.86B from original and updated all maps. Bought a cheap GPS antenna (£8.99!!) and it works perfectly, showing 8 satellites and gaining position very quickly, so its the roof unit, mine has the stubby antenna. As the cheap add-in GPS antennae are not waterproof I would like to replace the roof unit - trouble is there are several and they are not interchangeable, plus my New Look model doesn't appear in many search engines - even the owners handbook refers to the previous model! Any idea of the official part number of just the roof unit?
BTW updated firmware meant that I could use the driver's "comfort" seat movement and corner headlighting! Not managed to set the door mirrors to dip on parking yet though....
- GiveMeABreak
C15 Romahome White
CX 20 Polar White
Re: GPS antenna
@ DocJW:
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum. |
To Upgrade Your Membership & Donate Click Here For Further Information About Vehicle Parts and VIN Numbers Click Here |
