Painting Gabby
daviemck2006
- x 485
Painting Gabby
It has started. Gabby getting her freshen up. I’m going to do it all myself. The first stage is rubbing down all the bits that are getting filler. The rear door on the passenger side has a crease the length of it but it is not getting filled. I’m pleased to announce no further welding needed. She is as sound as a pound.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 1996
daviemck2006
- x 485
Re: Painting Gabby
Neither Alasdair, coach enamel with a roller the wet and dry it about 1800 grit or smaller grit then buff it. I've been part of doing that on coaches in the past and I should get a good enough finish and a thicker coat of paint. It's not going a standard xantia colour, and if I ether don't like it or make an arse of it, well it's only a 200 quid run around, although a loved one and not treated like a banger. The tiny hole you can see is the only iffy bit on the car, and it doesn't look like it was caused by rust, the filler on top of it was c?acking, so I just got rid of it and did what the previous repaired did, filled it again. Rain has stopped play now but that's a couple of hours today, that's enough. Tomorrow hoping to smooth the filler and apply primer to that bits then comes the rubbing the whole car down. It's really not bad for the age of the car, just a couple minor scrapes on the back corner and 3 of the bumper corners.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
bxzx16v
- x 34
Re: Painting Gabby
Enjoy your paintwork session Davie , I'm sure she'll look good when your finished. How's things going with the 407 ?
Mark
Mark
- x 8395
Re: Painting Gabby
Davie, I apologise for the dent above the rearlight cluster... I did that...
Reversed into a big rock in the car park at Southwick parkrun
Watching with great interest
daviemck2006
- x 485
Re: Painting Gabby
Your dent now has a lump of filler in it Jim. It will never be perfect, but will be better. Mark, the 407 is sitting untouched and unloved at the back of the drive. Not yet had the inclination to put it to a garage, and a rather large house expense means I can't afford to, so sit it will have to do. I would consider selling it as it is but it would be worth very little as a non runner. I have asked a couple of local garages and they have no interest in trying to fix it. Garages here are a waste of time.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
daviemck2006
- x 485
Re: Painting Gabby
As per usual do a bit of work one daý and be as much use as a wet paper bag for an ashtray on a motorbike the next.
Nothing done today.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
andy5
- x 103
Re: Painting Gabby
I don't know what you do about clear lacquer. Can colour be put over the top of it, or would the clear lacquer be removed to slightly further from the repair area, to give room to feather the edge of the paint and sand it down, then lacquer over the whole area?
daviemck2006
- x 485
Re: Painting Gabby
About 1/2 the lacquer is gone from it with a little help from a power hose. I'm going to use an orbital sander and possibly remove all the lacquer. But I think that if the lacquer is sound then it wouldn't need removing, just a light rub down. But then I've only really done single panels with rattle cans before, but they have all came out ok
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
superloopy
- x 19
Re: Painting Gabby
Depending on the 'result' davie you can come and rub down all of my lacquer on scraptiva. Been sitting as a non runner now for at least 2years and lacquer is almost non existent
Mike
daviemck2006
- x 485
Re: Painting Gabby
xantiamanic wrote: 10 May 2018, 12:04 Depending on the 'result' davie you can come and rub down all of my lacquer on scraptiva. Been sitting as a non runner now for at least 2years and lacquer is almost non existent![]()
NO
On Gabby, all filler bits rubbed down, a couple of skins of more filler, roof, bonnet, bootlid, door pillars all rubbed down, first coat of primer applied to all the bits which were rubbed down to the metal. Don't think there will be any more progress until at least Monday, apart from maybe putting more primer onto the bare metal bits. It will get possibly 3 coats of primer before flatting ready for top coat.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
bxzx16v
- x 34
Re: Painting Gabby
Looking forward to pics Davie.
Mark
Mark
Michel
Re: Painting Gabby
daviemck2006 wrote: 10 May 2018, 18:46 ...NO I'm not rubbing anything for anyone else, unless she is mid 30's, long blonde hair, blue eyes and an hour glass figure.
My new motorcycling buddy fits that description almost perfectly
superloopy
- x 19
Re: Painting Gabby
daviemck2006 wrote: 10 May 2018, 18:46xantiamanic wrote: 10 May 2018, 12:04 Depending on the 'result' davie you can come and rub down all of my lacquer on scraptiva. Been sitting as a non runner now for at least 2years and lacquer is almost non existent![]()
NONot rubbing anything for anyone else, unless she is mid 30's, long blonde hair, blue eyes and an hour glass figure. Ànd the chances of me finding one of them is nil to negative!
Not where i am presently davie ....you'd be in your element 'rubbing down' here in Puerto Rico, Gran Canaria. Lots to 'see'
Mike
daviemck2006
- x 485
Re: Painting Gabby
I’m on the final rub down of the primer before I start colour. The worst bit of doing paintwork is rubbing down. Even using an orbital sander on the big enough bits was a chore for my knackered body. Should be ready for colour tomorrow I hope. Or maybe not, I’m going to do the sills and door shuts in stone chip before the colour goes on. I may leave the sills black, it shall fit in with my colour scheme, which is top secret apart from one person who knows lol
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
