FAPLite
- x 2941
Re: FAPLite
Not tried your Fap thingy but I bought a dongle from Poundstretcher................for £1, it's tiny but seems to work fine on my old Dell laptop
Xantippa
- x 29
Re: FAPLite
FAPlite is interesting software, because it can even do some telecoding on Citroens if I understood correctly. However I got bluetooth -dongle, but it doesn´t work with that software (torque works just fine). FAPlite requires latest obd-protocols supported, but it's not easy to find on ebay those protocols these cheap bluetooth dongles on sale support.
- x 3566
Re: FAPLite
I shall venture out to my C5 tomorrow and see if I can get FAPlite to work on it using my OBDII bluetooth and Android devices.
leithant
- x 9
Re: FAPLite
Very useful on my C5 - ended up buying the full version through Amazon Apps.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased
95 Peugeot 306 S16
- x 3566
Re: FAPLite
Prompted by Xantippa's request yesterday, I downloaded FAPlite to see what it could do - and it's actually quite good
It worked 'straight out of the box' for me using an old OBDII reader I've owned about 4 or 5 years: FAPlite (as opposed the paid for version) gave me these readings straight away:
Not sure about the Fan Speed 100% reading though !!
If you go for the 'paid for' version you should get the following listed additions (note - some are already available in the free version) I tried out the cooling fan actuator test incorporated into FAPlite and it span up the engine fan no problem.
FAPlite reported a preheat fault but wouldn't clear it - not surprising really as I think that's a spurious fault anyway !
FAPlite worked straight away on both my Samsung Galaxy A3 phone and Lenovo tablet running Android 6.0.1
I'm very tempted to go for the paid for version, although more out of interest than any real diagnostics necessity.
Note - diagnostics performed on 2009 C5 X7.
- x 6956
Re: FAPLite
What about depressurising the hydraulic circuit? Are there any programming functions available (telecoding ECUs / Key programming etc?
- x 3566
Re: FAPLite
At present it seems to be aimed at engine and gearbox ECUs and I've seen nothing yet to indicate it'll communicate with the suspension (or any other) ECUs.
Link for PAID FOR version:
https://www.amazon.co.uk/FAP-Citroen-Pe ... B01LJUI2TA
- Supported INJ ECUs: EDC15C2, EDC17C10, EDC17C10_BR2, DCM3.5, DCM3.5_BR2, HDI_SID803, EDC16CP39, EDC16C3, DCM3.4, HDI_SID807_BR2, MED17.4.2, MM6LPB, MEV17.4_EURO4, DCM3.4P, HDI_SID807, MEV17.4_EURO5, MEV17.4.2, ME745, MED17_4_EURO5, SID201, DCM35_HY, J34P, MM6LP, ME749, MM6KP, EDC17CP42, MEVD17_4_2, EDC17CP11, MED17_4_EURO4, V46, DCM6.2, ME747, DCN2, V34.1, V46.21, EDC17C60, MED17.4.4, S2000PM2
- Supported gearbox ECUs: CFC300P, CFC300P_HY, AM6/AT6, AL4
- ELM327 Bluetooth or WiFi adapter required
- Read real time information from your Engine Management ECU
- All sensors displayed like in DiagBox/Lexia manufacturer diagnostic
- Now you can check condition of used car before buying
- Faults reading and clearing
- Fast logging of sensors data and displaying in chart or table
- Testing of actioners like engine fan, EGR, fuel pump, air mixer...
- Customizable display of sensors data
- Check condition of DPF/FAP and additive level
- x 3566
Re: FAPLite
Xantippa wrote: 17 Mar 2018, 18:26 FAPlite is interesting software, because it can even do some telecoding on Citroens if I understood correctly. However I got bluetooth -dongle, but it doesn´t work with that software (torque works just fine). FAPlite requires latest obd-protocols supported, but it's not easy to find on ebay those protocols these cheap bluetooth dongles on sale support.
Did you grant FAPlite 'Location Access' under App Permissions on your phone/tablet ? It requires this to be able to talk to the OBD reader.
- x 6956
Re: FAPLite
OK, so sounds like it would be useful as a portable and concealable tool for checking he status of a car before buying and reading / clearing faults - so much easier then turning up with a laptop and a mile of cable to the seller!
I suspect that it won't have any programming functionality or diagnostic troubleshooting at all as that will require licensing by PSA, but useful for the odd data telemetry and fault reading / clearing. Thanks for the update.
- x 3566
Re: FAPLite
It's useful if only to quickly and painlessly check how much additive is left in the reservoir
- x 6956
Re: FAPLite
And that too, yes!
leithant
- x 9
Re: FAPLite
Plus expect additional features as the developer is very active. In other words please buy the full version to support his work - it is worth it!
95 Peugeot 306 S16
95 Peugeot 306 S16
- x 1938
Re: FAPLite
As it uses the ELM327 interface would it not be missing the K-line and a few other pins? This would limit the number of ECUs it can see.
Having said that it looks like a good toy!
Xantippa
- x 29
Re: FAPLite
bobins wrote: 18 Mar 2018, 13:13Xantippa wrote: 17 Mar 2018, 18:26 FAPlite is interesting software, because it can even do some telecoding on Citroens if I understood correctly. However I got bluetooth -dongle, but it doesn´t work with that software (torque works just fine). FAPlite requires latest obd-protocols supported, but it's not easy to find on ebay those protocols these cheap bluetooth dongles on sale support.
I think there was a pop up for that and I granted access. It tries to connect few times, but then comes error about "bad clone adapter". Have to check that again though.
