Citroen relay stereo problem
This section is for General Enquiries or for Systems not Covered Above
mcwakelin
Unread post by mcwakelin »
Hi I have a 07 plate relay 2.2 I have converted to a camper but the stereo has problems.
1. Stereo will pick up local radio
2. Will loose signal when I move the van.
3. Traveling down the motorway it will pick up a local station for about 3 miles
I have changed the stereo with no joy
I have changed the Ariel no joy
Have installed a new Ariel no joy
Have put in a modern head unit still the same
x 1456
Re: Citroen relay stereo problem
Unread post by xantia_v6 »
Have you tried changing the antenna cable?
x 6957
It is likely to be water and/ corrosion in the aerial wiring or the small amplifier unit (if fitted). Sometimes water can get in and cause havoc.
mcwakelin
xantia_v6 wrote: 13 Dec 2017, 19:55 Have you tried changing the antenna cable?
Replace complete Ariel with cable etc
mcwakelin
GiveMeABreak wrote: 13 Dec 2017, 19:57 It is likely to be water and/ corrosion in the aerial wiring or the small amplifier unit (if fitted). Sometimes water can get in and cause havoc.
Ariel is connected directly to stereo
x 3306
Some Citroen aerials have an amplifier built into the base of the aerial. If water gets in here it can reduce the effective reception range of the radio.
x 1940
If the aerial base unit is an amplified type are you sure that it's getting a proper 12v feed? On PSA vehicles I have seen types which have a separate 12v feed and others which have 12v sent down the aerial lead. You obviously have to match the type to the 12v supply.
x 6957
As I already mentioned about the amplified aerial in my first post - here is the unit with the amplified base I mentioned - similar to this. I can't be specific without a VIN and an RPO - as there are so many variants of these vans and as some are Fiat Hybrids, not all the diagrams are available.
mcwakelin
Hi vin is VF7**************[VIN obfuscated, can be read by forum staff]********
Reason: VIN Masked
x 6957
Ok, it's as I originally posted - so no change (good guess :-D )
There's nothing about the base being amplified, and also no other identifiable amplifier boxes or adapters as there are in the C5 for example - but here is a better picture of the aerial fixing under the headlining:
mcwakelin
Ok a bit stuffed then as I have replaced the aerial and cable and stereo and the problem is still there so a bit lost now
x 1456
Try attaching a piece of normal wire (about 50cm) to the antenna socket on the radio, and see if that gets better reception, to at least prove that the head unit is working OK.
Bick
x 44
Unread post by Bick »
Its a long shot but i have seen alternator insulation breaking down or a alternator bearing running rough that has caused your exact symptoms.
mcwakelin
Cheers guys will try in the week
x 1456
Bick wrote: 17 Dec 2017, 10:25 Its a long shot but i have seen alternator insulation breaking down or a alternator bearing running rough that has caused your exact symptoms.
I presume that issue would only appear with the engine running?
