Diesel Pump
Eddie Nuff
- New User
- x 32
Diesel Pump
In the new year, when everything has quietened down and I have two minutes to think, I intend to set about the sinker, as in my sig. The underneath, bodywork and interior are done but the car is let down by a scruffy engine bay, so the intention is to remedy that and see how close to showroom condition I can get her. Hence the diesel pump, and other parts, are going to be vapour blasted.
So my questions are aimed at making this as smooth as possible;
When removing the diesel pump are there any procedures to follow?
Does the pump have to be drained down of diesel before removal?
Does the cambelt sprocket need locking out first?
Is there any special tool needed?
Are there any valves/seals/grommets that need to be removed before blasting?
- x 8427
Re: Diesel Pump
Eddie Nuff wrote: 03 Dec 2017, 16:31 So my questions are aimed at making this as smooth as possible;
Yes, remove the timing belt cover over the pump sprocket and bring the engine to time. Remove the fuel delivery pipes to the injectors as one of the first jobs you do to avoid stressing them.
No need to remove the cambelt as the sprocket will remain in place supported by the M8 bolts in the index holes...
When removing the pump, be very careful the woodruff key does not make a bid for freedom. Stuff the area with rags as if the key disappears down in the timing belt area you are in a world of pain... I have been thereThe stuffed rags will catch the key if it flies... When replacing he pump, use lots of grease to hold the key in place...
No.
Yes. Once in time, lock the sprocket using M8 bolts in BOTH index holes...
Yes, a special puller to pull the sprocket off the pump driveshaft. Easily made... I can supply details if you want...
All orifices need to be VERY THOROUGHLY sealed before doing any sort of cleaning...
Just shout if you need further information Neil
OnlineHell Razor5543
- x 3298
Re: Diesel Pump
CitroJim wrote: 04 Dec 2017, 07:37Eddie Nuff wrote: 03 Dec 2017, 16:31 So my questions are aimed at making this as smooth as possible;
No.
Don't forget to wash your mouth with coaltar soap, as you WILL be turning the air blue!
Just shout if you need further information Neil![]()
- x 8427
Re: Diesel Pump
James, you do make me giggle
I love your comment in blue above!
- x 3298
Re: Diesel Pump
If I can make one person a day smile I think I have made the day worthwhile. If I can make them laugh so much the better.
How are you getting on with that DIY book?
- x 8427
Re: Diesel Pump
Absolutely agree with that totally JamesHell Razor5543 wrote: 04 Dec 2017, 08:02 If I can make one person a day smile I think I have made the day worthwhile. If I can make them laugh so much the better.
Loving it
The other book is next to be read...
Did you get 'The Shepherd' back OK?
- x 3298
Re: Diesel Pump
I let Mike know that if he wanted to borrow it go ahead.
Eddie Nuff
- New User
- x 32
- x 8427
Re:
Those details will be with you as soon as I'm within range of my home... Can't get to my files where I am presently
Also, don't hesitate to ask for any further advice you may need...
Eddie Nuff
- New User
- x 32
- x 8427
Re: Diesel Pump
yes, but I'll forget unless I do it ASAPEddie Nuff wrote: 04 Dec 2017, 12:17 No need to rush, I aren't going to start on this until the new year.
Here they are...
The design:
What it looks like:
How to use it. (Engine removed for clarity) Works on both Lucas and Bosch pumps...
The bolts are M7... An odd size but you can 'borrow' a couple from the gearbox housing
moizeau
- x 423
Re: Diesel Pump
And leave the nut on the pump (unscrewed a few turns) to look after the thread and it stops the whole lot leaping off uncontrollably. Then you can remove the pulley and woodruff key easily without visiting the land of pain
Pete
- x 8427
Re: Diesel Pump
moizeau wrote: 04 Dec 2017, 19:18Then you can remove the pulley and woodruff key easily without visiting the land of pain
But no, you leave the pulley (sprocket) in place so that there is no need to disturb the cambelt
The puller is gentle enough to not cause any damage to the driveshaft threads...
Neil, on thing I forgot... Before you start, mark the position of the pump on it's cradle with a line across the pump flange to ensure that on reassembly the pump static timing is maintained...
moizeau
- x 423
Re: Diesel Pump
Yes Jim, meant to say 'remove the pump and key from the pulley'. Leaving the nut on has always been a habit, you don't know how stuck they can be, started the habit after removing a rotor on a motorbike crank that damaged the first thread
Pete
- x 8427
Re: Diesel Pump
moizeau wrote: 05 Dec 2017, 10:32 Leaving the nut on has always been a habit, you don't know how stuck they can be
And it's a good one too
I've had more pump sprockets off than I can count now and touch-wood they've always come off without any difficulty using my little puller...
