Citroen Xantia possible LHM leak
x 1460
Re: Citroen Xantia possible LHM leak
Unread post by xantia_v6 »
As a possible clarification, Citroen never listed the repair kit as fitting the Xantia. The same complete valve with the same part number was used on earlier models (e.g. the BX), for which the repair kit was listed by Citroen.
xantos
x 10
Unread post by xantos »
All you need is part 6 from ( part number 95 640 067) the picture...
Go with the part number to Citroen dealer and they should order it for you... It costs about 10,66 eur including VAT.
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
Dusan2222
Unread post by Dusan2222 »
I found a used cap from a scraped xantia. Hope i will get it replaced on Monday.
This is my Xantia :)
x 8406
Excellent! Your Xantia looks absolutely lovely Dusan :)
A Xantia is one of the very few cars that look good in silver...
x 1746
Looking splendid, Dusan.
xantos
x 10
Dusan2222 wrote: 21 Oct 2017, 18:44 I found a used cap from a scraped xantia. Hope i will get it replaced on Monday.
DON'T use a second hand cap... It will start to leak sooner or later... I strongly recommend that you buy a new one... It not expensive.
Dusan2222
Its impossible to find one here :( :(. My only hope was citroen dealership but they only offered the whole valve at a very high price
x 3296
Well (although I could not help), why not ask if somebody on the forum could get a new cap for you, and then get it out to you?
x 1460
xantos
x 10
Well when I was ordering valve cap for brake cylinder they also tried to persuade me that I need to buy the whole cylinder... And I persuaded them back that I need just the valve cap 8-)
From then on I just go with part number to the dealer and order what I need... They don't ask me anymore questions because they are ashamed that I know better than them :-D
x 8406
xantos wrote: 23 Oct 2017, 08:44 From then on I just go with part number to the dealer and order what I need... They don't ask me anymore questions because they are ashamed that I know better than them :-D
That's the very best way and exactly what I do ;) It just proves to them you are competent and know what you are doing :-D
Dusan2222
Okay, is the valve hard to reach. Where exactly is located and how to reach it. From the words of the mechanic in the citroen dealership, its very difficult to reach and it takes up to 2 hours to change it.
x 1460
Your car is (I assume) LHD, so the doseur valve is located more or less under the LHM tank. The rubber cap protrudes into the footwell but the valve must be unbolted from the car and moved into the engine bay to change the rubber cap.
x 8406
Removing the LHM tank, I believe, will give good access. Far better in fact than we 'enjoy' on RHD Xantias...
Dusan2222
So i just need to remove the LHM tank. No other parts to be removed? Are there any cautions that i need to be aware when removing the tank? Any special tools?
