new- to me- c5 problems
scas
Unread post by scas »
hi, my old 01 c5 2.2 4 speed auto has reached the end of the line, ive had it 6 years. i bought privately a 06 c5 2.0d 6 speed auto privately and i have a couple of questions-
the radio has a tel button, but ive no idea how to bluetooth it to a phone, when i search bluetooth from a phone it finds nothing-any ideas.
secondly and much more worrying is the gearbox issue. when driving at about 40mph, if you try to accelerate hard, when the box kicks down theres an awful noise and vibration for a split second but if you do it in semi auto theres nothing, also ive noticed on a hill if you try to pull away it takes a while to get going.
i suppose start by changing the oil, i read somewhere something about 2 solenoids-what are they?
any suggestions would be appreciated
EDC5
x 130
Re: new- to me- c5 problems
Unread post by EDC5 »
I'd say a gearbox oil change is in order as it probably hasn't been done before. I'm guessing you've got the Aisin 6 speed box.
With regards to the phone, I'm not sure however I think some C5's have their own sim tray for taking calls.
scas
thanks for the reply. i took it to an auto transmission specialist this morning. he plugged it into his scanner and there was no fault codes then drove it for a few miles, had a look at which box it was-cant remember what he called it- and told me that is was almost certainly the valve body.
he said about 800 euros new and the remanufactured ones were rubbish. he then told me that it,d be about 700 euros to fit and that it still might not fix the problem and the box itself may have to be rebuilt another 1000euros.
looking at videos on youtube, it looks like about a 3 hour job to change.
i can quite happily change the engine or gearbox on my transit rwd so im not mechanicly frightened. so should i just change the valve body or could it be something else?
x 6953
First, I would get it 'properly' diagnosed with a knowledgeable mechanic who has a 'Lexia' - that is the PSA group bespoke diagnostic and can provide far more information that generic or third party 'scan tools'. That is the only way to try and get a fuller picture of possible causes, not the 'could be this, could be that scenario' - that's a sure way to end up out of pocket and may not cure the problem. But as EDC5 has already said - the best thing you can do is to give it a proper gearbox oil change, which can eliminate certain problems - especially if you don't know if it has previously been changed.
As for your telephone issue - post up your VIN so I can determine the exact system and capabilities. The telephone system is internal that requires a separate SIM card inserted into the head unit (vertical slot to the right) - and does not support bluetooth. Bluetooth was not available on the C5 until the Mark III (X7).
scas
here in ireland there are very few people whod go near an auto box, he was using a snap on something to communicate.
vin is VF7**************[VIN obfuscated, can be read by forum staff]
scas
can i buy a lexia - looks like a few cables and a chip for a laptop-do i need a program after that or do the ones on ebay come with the program
eg
http://www.ebay.ie/itm/REV-C-LEXIA-3-PE ... SwRxtZyAW0
x 3280
That looks OK, and it appears to have all of the software. However, Easy Diagnostics also do a Lexia clone (with all of the cables and software), and will (with this code: FCFMEMBER15) sell it to you with a 15% discount.
http://www.easydiagnostics.co.uk/shop/4 ... 7/11178597
EDC5
x 130
http://www.ebay.co.uk/itm/CITROEN-C6-Au ... SwtfhYtZwp
That appears to be a brand new valve body (ifyou have the AM6 gearbox). I'm not sure how hard it would be to change but the access doesn't seem too bad. You do need a Lexia for that operation though I beleive as the gearbox ECU needs to re-learn the new solenoid valves.
scas
yes i dont mind throwing a few hundred at it-the labour will be free,.
how to find out which gearbox it is ? do citroen have a site like fords etis where you type in the vin number
x 6953
You have the BVA AM6 Gearbox according to your VIN.
scas
thanks-thats part one solved-what do do i have :shock:
scas
this is the radio in it btw, if theres no phone on it can i stick in an aux usb on the back. photo lifted from here
x 6953
Ok, so looking at your specs, there is no Telephone Kit supplied, so you just have the RD4 unit. This unit can support a CD-Changer - but in place of the CD, some have put a Yatour or similar device in that provides MP3 playback via a USB port or an MMC / SD Card - item here:
https://www.amazon.co.uk/YATOUR-Digital ... B005V756ZG
They do have another model that supports Bluetooth:
https://www.amazon.co.uk/Adaptor-Blueto ... F7ARDFS8HK
Although on the later one, you'll have to make sure the unit is not made by 'Continental' - if Magneti Marelli you should be ok - removing the head unit should identify it.
scas
thanks for all the replies, very helpfull. i think ill wait until when the car comes to a stop after a few seconds you feel the thump in the box.
on a different subject -15 fekin minutes to change a nearside parking light on the front grrrrrr
x 1438
Unread post by xantia_v6 »
I quick prod of Google produced the following, which may be relevant...
http://www.liontamer.net/forums/index.php?topic=136.0
