xantia hdi starter motor
- x 5582
Re: xantia hdi starter motor
I meant on a rolling road or similar James - even on a real MOT.
van ordinaire
- (Donor 2017)
- x 402
Jeep ones just have to put up with it!KennyW wrote:Thanks Ted,
I'm having more of these moments !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Chris, I would check the 'thingy' as they don't like water or muck as well.
Kenny
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
c.morewood
- x 55
I thought I'd publish the end result of the "starter motor failure". Turns out it wasn't the starter motor at all. It was the ignition switch. It failed again a couple of days before I went on holiday last month. Left it with the garage whilst I was away, expecting a new starter motor. Instead I have a rocker switch attached to the steering cover beside the ignition switch. I have to turn the key and hold the switch till she starts. I'm now wondering whether to leave as is or replace with another ignition switch? Presumably its easy enough to get the barrel out of the switch and to put it into another?
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
KennyW
- x 163
Removing the ignition barrel is easy Chris. If I remember correctly ignition barrel switch has a front and back which separates.
If you have access to a 2nd ignition switch the back parts and reassemble and problem solved.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
c.morewood
- x 55
Thanks Kenny
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
Timmo
- x 168
Is it the ignition switch that has failed or simply the feed wires? If the latter, relay mod in the circuit will most likely fix, or you could replace the rocker switch with a push button starter? (essentially the same as the installed switch)
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
- x 8093
Timmo wrote: 26 Sep 2017, 07:34 Is it the ignition switch that has failed or simply the feed wires? If the latter, relay mod in the circuit will most likely fix, or you could replace the rocker switch with a push button starter? (essentially the same as the installed switch)
Relay mod as per the V6 will work a treat on the HDi
KennyW
- x 163
I thought MK2's had the relay mod done as standard.
Kenny
Kenny
- x 8093
Only for the heater blower Kenny, not the starter motor...
c.morewood
- x 55
More details please Jim. Do you have a link to the page please? I tried a search but just came up with this thread.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 8093
c.morewood wrote: 27 Sep 2017, 22:17 More details please Jim. Do you have a link to the page please? I tried a search but just came up with this thread.
It's buried deeply in my blog I think Chris...
But meanwhile, this thread will give the bare details... Look at my post in in a little way down
https://www.frenchcarforum.co.uk/forum/ ... ay#p300584
Hope that helps...
c.morewood
- x 55
Thankyou Jim
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 8093
Chris, if you need any further details or how to fit the relay, just give me a shout...
KennyW
- x 163
How many relay mods are there Jim ??????????
Kenny
Kenny
elma
- x 287
On a MK1,
Starter motor
Headlamps
Fan motor.
Not sure if the MK2 needs the headlamp one or not.
Starter motor
Headlamps
Fan motor.
