xantia hdi starter motor
x 5690
Re: xantia hdi starter motor
I meant on a rolling road or similar James - even on a real MOT.
van ordinaire
(Donor 2017)
x 400
KennyW wrote:Thanks Ted,
I'm having more of these moments !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Chris, I would check the 'thingy' as they don't like water or muck as well.
Kenny
Jeep ones just have to put up with it! :lol: but THEY do suffer from Neutral Safety Switches, which can produce exactly those symptoms. Just a thought, no harm in a little X-polination of ideas :wink:
Citroens:-
'81 2CV Club :cry:
'05 C15 :!:
others:-
Jeep XJ Cherokees x 3 :?
'96 Cadillac Eldorado
'99 Cadillac STS :|
c.morewood
x 55
Unread post by c.morewood »
I thought I'd publish the end result of the "starter motor failure". Turns out it wasn't the starter motor at all. It was the ignition switch. It failed again a couple of days before I went on holiday last month. Left it with the garage whilst I was away, expecting a new starter motor. Instead I have a rocker switch attached to the steering cover beside the ignition switch. I have to turn the key and hold the switch till she starts. I'm now wondering whether to leave as is or replace with another ignition switch? Presumably its easy enough to get the barrel out of the switch and to put it into another?
'00 Xant 110HdiSX Est 83K "W"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
KennyW
x 165
Unread post by KennyW »
Removing the ignition barrel is easy Chris. If I remember correctly ignition barrel switch has a front and back which separates.
If you have access to a 2nd ignition switch the back parts and reassemble and problem solved.
Kenny
C3 1.4 petrol (SWMBO)
c.morewood
x 55
Thanks Kenny
'94 Fiat TipoTd 40K
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
Is it the ignition switch that has failed or simply the feed wires? If the latter, relay mod in the circuit will most likely fix, or you could replace the rocker switch with a push button starter? (essentially the same as the installed switch)
'58 C2 Code
'58 partner teepee outdoor
x 8468
Timmo wrote: 26 Sep 2017, 07:34 Is it the ignition switch that has failed or simply the feed wires? If the latter, relay mod in the circuit will most likely fix, or you could replace the rocker switch with a push button starter? (essentially the same as the installed switch)
Relay mod as per the V6 will work a treat on the HDi
KennyW
x 165
I thought MK2's had the relay mod done as standard.
Kenny
x 8468
KennyW wrote: 26 Sep 2017, 09:25 I thought MK2's had the relay mod done as standard.
Kenny
Only for the heater blower Kenny, not the starter motor...
c.morewood
x 55
More details please Jim. Do you have a link to the page please? I tried a search but just came up with this thread.
'94 Fiat TipoTd 40K
x 8468
c.morewood wrote: 27 Sep 2017, 22:17 More details please Jim. Do you have a link to the page please? I tried a search but just came up with this thread.
It's buried deeply in my blog I think Chris...
But meanwhile, this thread will give the bare details... Look at my post in in a little way down ;)
https://www.frenchcarforum.co.uk/forum/ ... ay#p300584
Hope that helps...
c.morewood
x 55
Thankyou Jim
'94 Fiat TipoTd 40K
x 8468
Chris, if you need any further details or how to fit the relay, just give me a shout...
KennyW
x 165
How many relay mods are there Jim ??????????
Kenny
elma
x 284
Unread post by elma »
On a MK1,
Starter motor
Headlamps
Fan motor.
Not sure if the MK2 needs the headlamp one or not.
