Citroen C5 2008 2.0 HDI Exclusiv - but is it Mk 2 or X7 !!!!
deaconj999
Re: Citroen C5 2008 2.0 HDI Exclusiv - but is it Mk 2 or X7 !!!!
VIN is VF7**************[VIN obfuscated, can be read by forum staff]************
Reason: VIN masked.
Reason: VIN masked.
- x 3565
Stickyfinger wrote: 27 Aug 2017, 08:33 TOP tips for a new owner..........
Get a garage (or DIY) to apply loads of waterproof thick grease to the steering rack Pinion valve stem/shaft)
............which is a surprisingly easy job to do as you can access the bit in question from the drivers footwell. Only requires a couple of bolts to be undone and a bit of wriggling
As yours is an early C5 X7, it'll almost certainly have had the steering rack replaced by now, so you might have a modified one fitted already.... or possibly not.
- x 6950
Ok, so confirmed as a:
C5 (X7) 4 DOOR SALOON 2.0 HDi 138 particle emission filter Manual gearbox 6. (Exclusive)
I've sent you a PDF with the complete specs.
deaconj999
Yep, got it thanks
