Hi
Does anyone know what are the differences between the following steering pinion valves
4048F9
4048P1
Are they interchangeable ?
Xantis - Interchangeability of streening pinion valves
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
- x 8
Re: Xantis - Interchangeability of streening pinion valves
Any one knows if they are interchangeable ? ?
aerodynamica
- x 215
Can't someone with access to the Service site punch in the part numbers?
Graeme M
OnlineStickyfinger
- x 1983
lancia58
- x 8
So can the 4048F9 be used instead of the 4048P1 ?
OnlineStickyfinger
- x 1983
Not a clue.....I cannot think many people would of tried as not many are in your (geographical) situation with limited spares/2nd hand units available.
- x 1438
I would say that the information suggests that they are not interchangeable, one is for cars with sinking suspension and FDV, and the other is for later cars with more conventional steering hydraulics.
lancia58
- x 8
What is FDV ?
OnlineStickyfinger
- x 1983
Flow Divider Valve
- x 1438
lancia58
- x 8
Very helpful indeed
Peter Duncan
"Are they interchangeable ? "
These ones are usually identical except for the high pressure input side. Some require a seal, some are metal on metal like on pump side also. If you transfer your old input socket to the new one it should work anyway. Same for the return side but imho those are similar (at least the ones I've seen).
